September 18, 2026, 07:42:43 am
Hoffman Amps Forum image Author Topic: Free stuff from uncle  (Read 13404 times)
Offline Bieworm
  • I like it loud!
« on: December 19, 2020, 11:39:57 am »
Today I got some very old stuff for free. An old philips oscilloscope, a signal generator and some other generator that produces various signals. Is that stuff I can use to make amp diagnosis? I mean, the scope is the size of a small amp with that round screen. The signal generator us 1hz to 100khz. So that one I can really use.
Re: Free stuff from uncle
« Reply #1 on: December 19, 2020, 02:49:00 pm »
If it works, then it's up to the operator to "understand" the "if it can" part  :icon_biggrin:
Offline Bieworm
  • I like it loud!
« Reply #2 on: December 19, 2020, 03:29:29 pm »
Be nice Shooter.. I'm still in the learning process 🤪🤪
« Reply #3 on: December 19, 2020, 04:23:30 pm »
What's the scope model number? Post a pic or two.
« Reply #4 on: December 19, 2020, 05:52:35 pm »
Be nice Shooter
I am in real life, I have to keep buying new shirts  :laugh:
you didn't state IF they worked, just you got old stuff.
for tube amps, any working scope will do just fine for 90% of the signal path/noise problems
Offline Bieworm
  • I like it loud!
« Reply #5 on: December 20, 2020, 02:59:22 am »
It's really old. There are tubes inside the scope !!!
Offline Bieworm
  • I like it loud!
« Reply #6 on: December 20, 2020, 03:10:29 am »
What's tha 3rd thing?
If I'm reeeeeeeal Lucky it's going to work. Probably need a scope to check these equipments. 😆😆😆
But I think its real cool stuff.. I mean,  there's tubes in there 👍👍👍
« Reply #7 on: December 20, 2020, 05:50:25 am »
Manuals are available on the net. Hope you can read Dutch!
The third piece is for use on obsolete analog color TV. It's of no use in the present world.
Offline Tom_Hull
« Reply #8 on: December 20, 2020, 06:32:30 am »
Uncles can be generous.very nice .Bieworm
I lucked out helping my freind ..Roger s uncle .to move
He gave me a 100w el34 amp .broken tube .u may know it ..the beer tube .
Scope.sound  generator.as well.
Fuzz pedals ,old school tube tape loop mixes tube 4reel to reel .and more stuff .too much stuff.mic stands guitar stands .
My shed is full of unclestools and no room to walk.
I love uncles
« Reply #9 on: December 20, 2020, 09:29:15 am »
 :laugh:
I thought you got government surplus when you said "uncle"
If the scope powers on and you have a narrow green line going horizontally you're golden.
Philips makes good stuff
Offline Bieworm
  • I like it loud!
« Reply #10 on: December 20, 2020, 10:30:03 am »
Geen enkel probleem!!! (Noooo problem) that's my main language.. I'm from Belgium
Me thinks that stuff is real high end professional stuff, that was used in the Philips research labs in Eindhoven  holland. 50 years ago or something like that. If broken should definitely be repairable
« Last Edit: December 20, 2020, 10:33:31 am by Bieworm »
Offline thetragichero
« Reply #11 on: December 21, 2020, 01:23:59 am »
that third item might be a treasure trove of parts you can use in other stuff. if it's not full of tubes might have some nice old transistors that could be used in fuzz pedals
obsolete test gear, old organs left by the side of the road... all contain fun stuff
Offline Bieworm
  • I like it loud!
« Reply #12 on: December 21, 2020, 03:56:48 am »
You're probably right,  but tubes would be a real surprise.. there ain't no cooling vents on that device.
« Reply #13 on: December 21, 2020, 06:21:11 am »
That PM 5105 looks similar to my HP 204D...
Offline Bieworm
  • I like it loud!
« Reply #14 on: December 21, 2020, 06:56:53 am »
To track down oscillation in the amp I should feed a signal into it at the grid of the 1st triode, no?
What frequency should I start with? If I understand this correctly it should be above speaker max frequency range? So above 5kHz.. what do you suggest?
« Reply #15 on: December 21, 2020, 07:58:05 am »
start easy, use the scope to "look" for the oscillation.  If you find it, knowing the frequency of it can help determine what's causing it.
since it's there already, adding a "new" signal with a seg-gen might get confusing
« Reply #16 on: December 21, 2020, 12:44:36 pm »
that third item might be a treasure trove of parts you can use in other stuff.....
Not really. You could harvest dozens of transistors, some Ge, a couple 30W types. (I was however surprised that it IS transistors, not chips.) Frank has the manual:
https://tubedata.tubes.se/other/sos/Philips_PM5508_PAL-ColourPatternGenerator_OM.pdf
Offline Bieworm
  • I like it loud!
« Reply #17 on: December 21, 2020, 12:50:31 pm »
Better store it away then... who knows when the crops will come in handy some day
« Reply #18 on: December 21, 2020, 12:55:46 pm »
EDIT -- most transistors are Silicon, nothing special. The power regulator has Ge. I would not be sure Frank's manual is 100.0% correct-- the high-profit low-volume box begs for running production changes as the transistor art advances and as trailing-edge types pile-up behind the factory.
Offline Bieworm
  • I like it loud!
« Reply #19 on: December 21, 2020, 01:15:03 pm »
That scope OTOH contains real treasures might it be broken. Lots of Ge transistors and quite a few tubes. ECC88 (4 pcs)
Dude, that is (to me) real complex stuff put together...
Offline Bieworm
  • I like it loud!
« Reply #20 on: December 22, 2020, 01:51:25 pm »
Is this a normal signal with the probe touching nothing? When I ground it to its ground clip it flattens out ...
« Reply #21 on: December 22, 2020, 02:43:20 pm »
congrats! you have a working oscilloscope!
Offline Bieworm
  • I like it loud!
« Reply #22 on: December 22, 2020, 02:53:06 pm »
Thx! This is new to me.. next hapter in amp building for me. A necessary and logic one
« Reply #23 on: December 22, 2020, 03:50:02 pm »
Ideally it's flat with no probe connected.
but any green trace is a good start
find a signal source and test further.
« Reply #24 on: December 22, 2020, 06:36:05 pm »
you have 1V calibration terminal (on the right of the LEVEL knob) - connect your probe to that  you should see a square wave that spans 4 vertical divisions on the graticule.
move the TRIGG. source switch switch to YB (photos show probe connected to BEAM B).
move the TRIGG. mode switch to NORMAL
set TIME/Div to 20uS (rotate vernier - the red hash marked control fully clockwise) - should display 2 full cycles IF it's a 1KHz source.
set BEAM B to X1 (not X10) and V to .5V (rotate the vernier - the red hash marked control fully clockwise).
touch the probe to the CAL 1V terminal.
Offline Bieworm
  • I like it loud!
« Reply #25 on: December 23, 2020, 01:43:54 am »
Do I connect the signal generator to it to put in a 1kHz signal?
« Reply #26 on: December 23, 2020, 09:14:47 am »
touch the probe to the CAL 1V terminal.--pete
« Reply #27 on: December 23, 2020, 12:15:02 pm »
Normally there is 50/60Hz on a no-connection probe if you turn-up enough.
Because it is capacitive coupling, the highs are enhanced, so the "sine" will be jaggy.
