August 29, 2026, 07:24:37 pm
Hoffman Amps Forum image Author Topic: buzz on volume control from about 0 to about 2-3, quiet when higher  (Read 6103 times)
Offline isaac_teller
What would cause this? Thank you.
Offline Latole
Re: buzz on volume control from about 0 to about 2-3, quiet when higher
« Reply #1 on: December 21, 2020, 02:59:59 pm »
Buzz or scratchy volume ?
Wich amps ?
I had a scratchy volume pot on vintage amp ; answer : bad filter caps
A DC leaky signal cap could be a issue too
« Reply #2 on: December 21, 2020, 03:20:49 pm »
Do the simple stuff first. Test the pot. Ohm meter connected to ground and wiper. Set the pot to zero. Resistance should be close to zero ohms. Now turn the pot up slowly. Resistance should smoothly increase. If you don't have an analog meter you will have to turn up very slowly so the dmm display can do it's sample/update.
Or you could just replace the pot and re-evaluate.
« Reply #3 on: December 21, 2020, 04:46:56 pm »
Buzz on zero?
Pot "ground end" is not at same potential as next-stage's ground reference.
« Reply #4 on: December 22, 2020, 06:05:31 am »
It’s unhelpful to ask technical generic questions, as generic answers are impossible. Or at least are rather more complex than necessary.
As the particulars of any scenario are critical facts.
Buzz on zero?
Need the schematic or at least some specifics on the amp in question.
As with some, eg 5E3, the volume control isn’t wired as a pot, so the issue could be due to poor lead dress or a hummy tube with unbypassed cathode.
« Last Edit: December 22, 2020, 06:11:58 am by pdf64 »
« Reply #5 on: December 22, 2020, 06:29:15 am »
The amp is a 50 watt Marshall JCM800 style with reverb.
Offline Latole
« Reply #6 on: December 22, 2020, 07:59:03 am »
« Reply #7 on: December 22, 2020, 09:38:01 am »
Definitely a buzz(50 Hz)
« Reply #8 on: December 22, 2020, 01:56:20 pm »
Schematic - there lottsa jcm800 models?
Is it a DIY?
Was it ever buzz free?
What controls affect the buzz? Has a tube issue been eliminated?
What’s the resistance between any part of the heater circuit and chassis 0V?
Offline Latole
« Reply #9 on: December 22, 2020, 02:37:53 pm »
Is it a DIY?
IMO, with reverb, it is a DIY
I built from scratch a Marshall Master volume  model 2204 with reverb "a la Fender"
Work great
Offline 2deaf
  • Now too deaf for 100 watts
« Reply #10 on: December 22, 2020, 03:30:27 pm »
I have two Marshall JCM800's with reverb, so reverb is not a distinguishing feature of DIY.
Offline Latole
« Reply #11 on: December 23, 2020, 03:13:54 am »
Always something to learn here, thank you
Offline aabbs20
« Reply #12 on: December 23, 2020, 09:02:06 pm »
Is it a DIY?
I don't mean to hijack this thread, but this is interesting to me. Where did you insert the reverb?
Work great
{EDIT -- untangled quote -- PRR}
« Last Edit: December 24, 2020, 10:08:05 pm by PRR »
Offline Leevi
    • Rikstone
« Reply #13 on: December 23, 2020, 10:00:21 pm »
Based on the similar cases I have had it can also be a wiring issue.
Try to move the signal wires and listen if there is any change.
/Leevi
« Last Edit: December 23, 2020, 10:08:20 pm by Leevi »
