August 29, 2026, 07:24:30 pm
Hoffman Amps Forum image Author Topic: Imperial clone OD channel change  (Read 3867 times)
Offline Bieworm
  • I like it loud!
« on: January 13, 2021, 11:05:56 am »
Hey guys.
As some of you know I built an imperial clone a while ago..
But time playing it has told me that the OD channel is not what I expected. You can dial in a nice tweedy tone but when the midbite knob is dialed that nice tone changes into a raspiness that's out of control. I ended up changing the paraphase PI into a LPT PI which I find much better. But I still don't like the midbite overriding the tone knob settings. I have drawn a schematic to turn that channel into something more 'marshallesque'. Could some of you wizards check out if it's a go or no-go? And what changes do I need to perform?
Thanks mucho 😉
Offline Bieworm
  • I like it loud!
Re: Imperial clone OD channel change
« Reply #1 on: January 14, 2021, 07:50:28 am »
Nobody?
« Reply #2 on: January 14, 2021, 09:06:35 am »
Sometimes people just don't have any comments. Doesn't mean we don't still love you.   :icon_biggrin:
Offline Bieworm
  • I like it loud!
« Reply #3 on: January 14, 2021, 09:24:35 am »
I had the chance to perform the changes yesterday evening. It works actually, but there are some (un)expected side effects  . I haven't had the chance to fully test it.. but first findings here:
- I have the impression the overall volume is less than before
- still fizz I think, but clearly less.. like I said, I have to test it somewhat better
- looking at the voltages I noticed that V2B (2nd stage clean channel) have gone up. I will leave that for now and try to tweak the voltages of the OD channel
- V1B and V2A: raise the plate resistor from 100k to 120k and see where that puts them? Should I simultaneously lower the cathode resistors or do that as step 2?
- OR... should I Raise the plate resistor of V1B to start off with higher voltages and see where that puts the rest?
