August 29, 2026, 05:52:18 pm
Hoffman Amps Forum image Author Topic: Fixed bias 5D3  (Read 5028 times)
Offline Leevi
    • Rikstone
Fixed bias 5D3
« on: January 18, 2021, 07:08:44 am »
Has anyone built 5D3 with fixed bias?
The PI inverter must probably be changes?
https://el34world.com/charts/Schematics/files/Fender/Fender_deluxe_5d3.pdf
/Leevi
Offline 66Strat
Re: Fixed bias 5D3
« Reply #1 on: January 18, 2021, 10:53:33 am »
The 5D3 PI won't work with fixed bias. The PI from the Ampeg SB12 will work with fixed bias. The SB12 PI is a self balancing paraphrase that is comparable to the 5D3, except that the SB12 has a negative feedback loop. The feedback loop could be eliminated to get even closer to the 5D3 performance characteristics.
https://el34world.com/charts/Schematics/files/Ampeg/Ampeg_sb12_schematic_6l6_ver.pdf
Regards,
JT
Offline 2deaf
  • Now too deaf for 100 watts
Re: Fixed bias 5D3
« Reply #2 on: January 18, 2021, 12:32:43 pm »
The PI itself doesn't need to change.  There would just need to be another set of blocking capacitors before the 6V6 grid leaks.
Offline Leevi
    • Rikstone
Re: Fixed bias 5D3
« Reply #3 on: January 18, 2021, 01:14:28 pm »
Would the NFB work with the current PI?
/Leevi
Offline 2deaf
Re: Fixed bias 5D3
« Reply #4 on: January 18, 2021, 01:37:51 pm »
NFB could be added by elevating the 1500/25uF cathode of the inverting stage and running a resistor from the speaker jack to the elevating resistor.
Offline Leevi
    • Rikstone
Re: Fixed bias 5D3
« Reply #5 on: January 20, 2021, 12:58:58 am »
Now the first tests have been done and both changes work excellent.
I used 100n capacitors to separate the inverter part and 820R for NFB. I also replaced the original 50n caps with 100n.
Thank you for the tips.
/Leevi
