August 29, 2026, 07:28:52 pm
Hoffman Amps Forum image Author Topic: Extend bias range  (Read 4218 times)
Offline Bugman3183
Extend bias range
« on: January 18, 2021, 01:26:17 pm »
Hello all,. Recently came into possession of a 68' custom deluxe reverb, and decided to swap the gz34 with a 5y3 ( just personal preference).  Using a probe (type that goes between socket and tube)  the highest I can adjust the tubes to is 12 ma.  My question is can I increase the range of bias by lowering the value of r59 from 22k to around 15k or so.  Or is there something else that needs to be done.  Thank you.
« Last Edit: January 18, 2021, 02:18:12 pm by Bugman3183 »
Well, you know....sometimes you gotta race.
Re: Extend bias range
« Reply #1 on: January 18, 2021, 02:03:59 pm »
can I increase the range of standby by lowering the value of r59 from 22k to sound 15k or so
Yes. I would not go below about 10K.
Offline Bugman3183
« Reply #2 on: January 18, 2021, 02:21:44 pm »
Thanks for the reply slucky.  I'm cracking up at myself after reading my post( damn auto correct).  I've edited the post and it's hopefully easier to follow now.
Offline glass54
« Reply #3 on: January 18, 2021, 03:43:41 pm »
Hi Bugman
You could fit 1R Metal Films on Cathodes (Pin 8) on V7 and V8  :icon_biggrin:
Really easily monitoring of currents without fitting/removing probes.
Kind regards
Mirek
"To measure is to know"
