August 29, 2026, 07:23:36 pm
Hoffman Amps Forum image Author Topic: Unusually high cathode voltage in single ended plexi  (Read 5798 times)
Offline isaac_teller
« on: January 24, 2021, 09:45:11 am »
Hello. I mated a plexi preamp to a 6V6 single ended output. I don't know why but I'm getting 41 volts on the cathode of the 6V6 with a 6V6 plate voltage of 300 volts. What gives? The preamp is everything up to the 0.022 cap before the phase inverter.
Re: Unusually high cathode voltage in single ended plexi
« Reply #1 on: January 24, 2021, 09:55:24 am »
My bad. This is the schematic.
« Reply #2 on: January 24, 2021, 10:01:58 am »
Still can't see the 6V6 which is supposedly the problem :-)
Have you double-checked (metered) the R-value of the 6V6s cathode resistor?
« Reply #3 on: January 24, 2021, 10:04:32 am »
This is just the schematic of the preamp. The 6V6 comes right after the last 0.022 cap before the phase inverter. The cathode resistor of the 6V6 is 470 Ohms with a 50 mf bypass cap.
« Reply #4 on: January 24, 2021, 10:22:39 am »
my math says that's ~~~ 14W a tube, pretty close to normal, what's it sound like?
EDIT:  I assumed 2 6V6's
If only one you have a problem  :icon_biggrin:
« Last Edit: January 24, 2021, 11:01:49 am by shooter »
« Reply #5 on: January 24, 2021, 10:23:29 am »
Still unclear exactly how the 6V6 is connected to that cap. Surely you don't have the PI tube and circuitry? Surely you have a resistor from 6V6 pin 5 to ground? The voltage on pin 5 should be zero.
« Reply #6 on: January 24, 2021, 11:23:44 am »
The 6V6 connects to the preamp similar to how the EL84 connects to the preamp here. Turns out that I forgot to put a 220K resistor from pin 5 to ground, like you said.
https://www.tube-town.net/cms/userfiles/downloads/jim-schem_layout.pdf
