August 29, 2026, 07:33:10 pm
Hoffman Amps Forum image Author Topic: 1M Gain pot / voltage divider question  (Read 4198 times)
Offline Bieworm
  • I like it loud!
« on: January 25, 2021, 11:02:30 am »
To the more experienced here...
Between the 1st and the 2nd preamp stage I have put a 1M pot that serves voltage divider. Classic setup... 1st stage plate - .01uf cap - 1M pot divides voltage between grid 2 and ground. The 2nd stage is a parallel triode with cathodes splitted.
I find that on the 1st half of the pot there is too little low end. Is there a way to thicken the sound there without fattening it up too much on the 2nd half of the dial?
Offline jordan86
Re: 1M Gain pot / voltage divider question
« Reply #1 on: January 25, 2021, 11:10:23 am »
A larger coupling cap coming off that first stage before the pot could help. .022 is common. Or a larger bypass cap at that first cathode. You may get too much low end with the gain higher though. Could correct it with a smaller coupling cap coming off the next stage plate.
