September 18, 2026, 02:15:18 am
Hoffman Amps Forum image Author Topic: Can someone link me a part for bias test points or something similar?  (Read 5076 times)
Offline paintballnsk
Hi,
I have a little project I'm working on and I need something similar to the testpoints found on some amps that have bias test leads in the back.
Anyone know what that part is called and maybe have a link to some?
Thanks!
Re: Can someone link me a part for bias test points or something similar?
« Reply #1 on: February 08, 2021, 01:45:16 am »
2mm probe tip jack.
https://hoffmanamps.com/MyStore/perlshop.cgi?ACTION=enter&template&thispage=JacksPlugs&ORDER_ID=!ORDERID
$1.56 each from hoffman.
invest in a 1/4" lock washer or 1/4" star washer for the nut side.
Offline Latole
« Reply #2 on: February 08, 2021, 03:25:18 am »
2mm probe tip jack.
Yes, that is what I use too.
You need 1 ohm resistor.
« Reply #3 on: February 08, 2021, 07:21:11 am »
2mm probe tip jack.
Fixing the link so it does not point to your shopping cart
jacks- Plugs page
https://hoffmanamps.com/MyStore/catalog/JacksPlugs.htm
