August 29, 2026, 07:28:53 pm
Hoffman Amps Forum image Author Topic: '55/'56 5E3 on the bench - filament question  (Read 3850 times)
Offline fdesalvo
  • "...I can walk!!"
    • Forgotten Gear Restorations
« on: February 24, 2021, 10:52:13 am »
Hi, all.
I've got a late '55/early '56 5e3 on the bench.  Owner wanted a cap job, some protective mods (backup rect diodes/MOVs on OT secondary), and some noise reduction.  This is his amp, which is routinely gigged, so he has no cares of future value.  I've updated grounding after installing the protective mods and completing the cap job, but some hum remains from the heater circuit.  The pilot lamp housing only has a hot lug and as you'd expect, the filaments are ref'd to ground at each socket.  Have any of you updated this to twisted pair with an artificial CT to ground?
TIA and I hope you all have been well
~f
FDeSalvo,
Principal Engineer & Owner,
Offline thetragichero
Re: '55/'56 5E3 on the bench - filament question
« Reply #1 on: February 24, 2021, 10:59:30 am »
sounds like a good plan to me, either two 100 ohm resistors or a humdinger pot of ye're feelin' fancy
