September 14, 2026, 05:13:08 pm
Hoffman Amps Forum image Author Topic: Marshall Vintage Modern 2466 amp ; looking for Middle pot  (Read 8664 times)
Offline Latole
« on: February 27, 2021, 03:19:58 pm »
Hi ,
I have a Marshall Vintage Modern 2466 amp with intermittent Middle pot.
Clean it with Deoxit with no success. There are some hole from the front of the pot
It is a B25 K like the pictures It is a green pot , the blue one is to show more the flat shaft.
I can't find one anywhere. Can you help me ?
Thank's
« Last Edit: February 27, 2021, 03:27:49 pm by Latole »
Offline acheld
Offline Latole
Re: Marshall Vintage Modern 2466 amp ; looking for Middle pot
« Reply #2 on: February 28, 2021, 03:14:37 am »
Is this close enough?
https://www.tubesandmore.com/products/potentiometers_0?filters=2341a2403
Thank you.
I look there before, there is only a 20 K pots, not 25k.
Same value everywhere.
I don't know how a 20K will work for middle tone circuit ? It could be not too bad ? Or I'll loose some middle ?
« Last Edit: February 28, 2021, 03:18:06 am by Latole »
Offline Latole
« Reply #3 on: February 28, 2021, 04:31:22 am »
I look at more 30 stores with Google selling Marshall parts.
The only pot available is the 20k .
I live close to the Quebec province Marshall Products distributor, West Coast Music. I'll go there next open day
Offline Bieworm
  • I like it loud!
« Reply #4 on: February 28, 2021, 09:35:59 am »
Maybe put a 5k resistor in series to get the 25k. Who sets his knob to zero anyway?
Offline Latole
« Reply #5 on: February 28, 2021, 09:43:30 am »
Yes, why not, thank's.
Offline thetragichero
« Reply #6 on: February 28, 2021, 10:17:40 am »
or if you can get a larger value pot the appropriate value resistor in parallel to the outer lugs to get 25k
Offline Latole
« Reply #7 on: February 28, 2021, 10:33:28 am »
You are 100 % right
A 100 K is available .
Thank you
https://www.tubesandmore.com/products/potentiometer-marshall-linear-11mm-pc-mount-square
« Reply #8 on: February 28, 2021, 11:05:08 am »
33k resistor puts you closer to 25k than probably the original
Offline Latole
« Reply #9 on: February 28, 2021, 11:22:45 am »
I will try, I have many 100K pots and resistors.
Thank's
Offline Bieworm
  • I like it loud!
« Reply #10 on: March 01, 2021, 12:10:37 pm »
I prefer 50k for mid pot. It does all a 25k can do, and beyond...
It's a common mod on 18W TMB amps.. part of the jalapeņo tone stack
Offline Latole
« Reply #11 on: March 01, 2021, 03:31:25 pm »
Good to know. Thank's
Offline Latole
« Reply #12 on: March 01, 2021, 03:40:52 pm »
I think I fix the pot, work fine since yesterday.
1- I spray Deoxit on two holes ( picture ) . These holes make Deoxit go inside the pot.  Feeling change when turning pots . I do all pots
2- I close the 4 pressure tabs, two where loose ( picture)
Offline Latole
« Reply #13 on: March 02, 2021, 04:06:00 am »
I have noticed that these potentiometers are fragile and can age prematurely.
Mainly with play in the shaft if you push the button, the potentiometer could become intermittent.
To prevent this play, I installed nylon spacers found at Home Depot in bulk in locker # 3580 in Canada. To see the photo.
This same type of pots would also be found on the models
CM2000 series TSL100, TSL122, DSL100, DSL50, DSL401 and VS65R well as some of the late 90's ValveState models.
These spacer do not change the appearance or operation of the knob at all.
« Last Edit: March 02, 2021, 09:14:22 am by Latole »
Offline Latole
« Reply #14 on: March 04, 2021, 03:08:47 am »
My answer to a e-mail ( see screen picture)
Thanks for your feedback. In the meantime, I managed to repair the potentiometer.
If the repair does not last over time, I will order from you. I keep your reference.
