September 14, 2026, 10:20:58 pm
Hoffman Amps Forum image Author Topic: How to troubleshoot this?  (Read 7099 times)
Offline JustMike
« on: February 27, 2021, 04:57:50 pm »
I picked up a Marshall 4203 Artist head that is dead. It's a hybrid amp that has a solid state front end into a 30w EL34 output section. I've determined that the PT primary is shorted. I guess it's worth a $100 investment in a new PT, but what if something else is wrong with the amp? I don't want it to turn into a money pit.
 I can assume it's going to need a cap job.
 If the OT reads minimal resistance on it's windings, I think I can assume that it's OK.
 The solid state preamp may be a PITA to troubleshoot and I'm concerned about that because if lightning or a power surge took out the PT, who knows what it did to the rest of the circuit. I think I'd feel OK if I can troubleshoot the preamp with a +-15VDC PSU.
 Any tips for troubleshooting this as is?
I'm learning...
Re: How to troubleshoot this?
« Reply #1 on: February 27, 2021, 06:02:01 pm »
pitch it, build a simple tube amp
otherwise; surf up "troubleshooting complex circuit boards"
Offline thetragichero
« Reply #2 on: February 27, 2021, 06:39:37 pm »
these sell for about 400 bucks on reverb. preamp about as complex as a distortion pedal, so should be easy to troubleshoot (especially if you have a scope). doesn't look like any specialized/obscure ics so if one is toast common 4558/tl072 types should just sub right in
Offline JustMike
« Reply #3 on: March 05, 2021, 01:37:19 pm »
I'm in the process of replacing the Power transformer and just noticed that pin 7 is tied to ground. It looks to be original factory wiring. The new PT doesn't have any secondary center taps (like the original). I'm thinking that I should make an artificial CT for the heaters, but I'm also assuming that this method that I know nothing of was good enough for Marshall, so why mess with it?
 What say you?
I'm learning...
« Reply #4 on: March 05, 2021, 02:11:32 pm »
the original wiring has the heaters like fender did with the champ with one side going to ground. yes, if it were my amp i would remove the connection to ground on the 6.3v and wire in an artificial center tap.
« Reply #5 on: March 05, 2021, 02:33:46 pm »
Why indeed. Let it be.
Offline JustMike
« Reply #6 on: March 06, 2021, 10:06:31 am »
Got the transformer wired in, changed the dual 50 & 33 filter caps, tested voltages-all nominal. Plugged in some tubes and applied power. I'm getting filaments and all voltages are spot on. But there's a faint hum in my bench speaker even though the amp is on standby. There are a couple of 47u caps on the +-15v preamp rails. Coincedently, this node/secondary is always hot and not affected by the standby switch.  (thinking out loud here - But how would the hum be getting thru the output stage and to the speaker?
I'm learning...
« Reply #7 on: March 06, 2021, 10:20:39 am »
Faint hum lets you know the amp is on. Could be coupling between the PT and OT.
Offline JustMike
« Reply #8 on: March 06, 2021, 03:05:13 pm »
 I'm assuming then that this could be the fault of the new PT, since I don't think this level of hum would be acceptable from the factory. I also assume a quick test would be to power it up with the power tubes pulled and if there's hum it pretty much has to be xfmr coupling?
I'm learning...
Offline JustMike
« Reply #9 on: March 10, 2021, 07:39:18 am »
 As a follow up, I rotated the OT 90 deg. which moved it about 2" farther away from the PT. Little if any difference. I then bolted a 3-1/2"x 4" piece of steel (from an old 2RU blank panel) to the chassis in between the xfmrs and it made little difference.
I'm learning...
« Reply #10 on: March 10, 2021, 07:50:17 am »
If possible, unbolt the PT from the chassis but leave the wires connected. Try to support the PT so it does not touch the chassis. Still got faint hum?
