September 14, 2026, 10:57:15 pm
Hoffman Amps Forum image Author Topic: Can I run the wire to the cw terminal of the presence pot with tone pot wires?  (Read 4440 times)
Offline Mike_J
Really impressed with p2pAmps build on the Doug's Custom Boards post. Mike runs his wires going to the pots across his buss bar. Makes a lot of sense since the buss bar is essentially chassis ground and I remember seeing Fender twist the wires together going to the pots from their board so keeping them together is probably not an issue. Plus it looks amazingly neat.
Only question I have is since the presence pot is a part of the power side of the board should I keep the wire going to the presence pot separated from the tone control pot wires which are preamp related. Not a big deal to keep them isolated but I was curious none the less. Probably easy enough to test if my radial ecaps ever get here.
Mike
Offline p2pAmps
    • p2pAmps
So far I have not had any issues with running the presence wire on the buss, but thats just me...  I would try both ways and see how it reacts.
Cheers
Everything Affects Everything
To do so seems contrary to the principles of good layout / lead dress.
ie if there’s lots of gain and phase shift between things, keep them separate.
