September 14, 2026, 01:59:38 pm
Hoffman Amps Forum image Author Topic: Inpedance of output transformer  (Read 5396 times)
Offline jamesedmunda
« on: March 19, 2021, 05:03:05 pm »
Hi,
 I have a schumacker ot stamped Fender 022889, E18 606 710.
 I want to use in a Silvertone 1474 that uses 4 6l6gc.
 put 22vac into the secondary  and got 1 volt out for a 22 to 1 turns ratio which I squared then multiplied by 4 for
1936 . Does this sound right for a 4 ohm output.
 Thanks in advance, James
Offline 2deaf
  • Now too deaf for 100 watts
Re: Inpedance of output transformer
« Reply #1 on: March 19, 2021, 05:16:38 pm »
022889 is the OT on Twin Reverbs and Dual Showmans, both 4-6L6 into four ohms.
« Reply #2 on: March 19, 2021, 08:48:57 pm »
Thank you
« Reply #3 on: March 19, 2021, 10:24:20 pm »
 got 1 volt out for a 22 to 1 turns ratio which I squared then multiplied by 4 for 1936 . ..
yep. 2k for 4 x 6L6 in PP
Offline Latole
« Reply #4 on: March 20, 2021, 03:53:10 am »
Have look at hammond Transformers you'll know right now .
You'll see 4 ohms xfrs have a 2 K impedance for 100 watts outputs
https://www.hammfg.com/fr/electronics/transformers/classic/1750?referer=1101
« Last Edit: March 20, 2021, 03:58:21 am by Latole »
