September 18, 2026, 06:31:41 am
Hoffman Amps Forum image Author Topic: Mini breadboard.  (Read 4977 times)
Offline pullshocks
Mini breadboard.
« on: March 22, 2021, 12:47:37 am »
Some of you on this forum have breadboards bigger than my whole house.
Here's a "kinda sorta" breadboard in an Judybox amp chassis I got years ago.  It has a PT with 265-0-265 and 320-0-320 taps, and an available 45 volt bias tap, if I ever venture into fixed bias circuits.
My goal with this is to try a few different preamp circuits
The circuit board is in 2 layers.  The longer, lower layer has a generic 6v6 push pull cathode bias power amp soldered in place.
The upper layer consists of  4 rows of terminal strips, one of which is wired up as a ground bus.  Leads are soldered to the tube sockets and can be connected t the screw terminals.  It will accommodate all the preamp circuits I had in mind (thank you DIY LC for helping me confirm that)
It takes a fair amount of time to wire it up initially, getting the leads bent to fit the spaces.  But disassembly and temporary connect and disconnect is a lot quicker for me than desoldering and resoldering.
Once wired up, a lid can be screwed on the shell. and within reason, moved around like any other amp head.  I wouldn't take it on a world tour,  but the assembly is secure enough to move from the shop to a playing area for playing tests.
First up is the Benson Monarch.
Offline acheld
Re: Mini breadboard.
« Reply #1 on: March 22, 2021, 09:23:11 am »
I like the approach.
With a similar goal in mind, I put together a set of pre-configured PCBs from Merlin's website.  These boards are engineered well, BUT are a pain in the neck to tinker with as you have to dismount the board from the chassis in order to desolder any component.
In addition, it's a bit difficult to keep track of  what trace connects where . . .
So, your idea is the winner.     Merlin's idea -- and my implementation of it -- not so much.
