September 15, 2026, 11:06:28 pm
Hoffman Amps Forum image Author Topic: Not Seeing High Voltage in Preamp Tube Pins  (Read 8564 times)
Offline Matt-O
« on: April 06, 2021, 08:37:19 am »
Hello there -
I'm new the forum, and I'm a relative noob at amp wiring (although I've done a lot of simple amp mods and a lot of pickup harness wiring). Recently, I decided to get into more advanced amp wiring by overhauling my Fender Pro Jr. with Hoffman's turret board kit. I completed the wiring a few days ago, and I've double-checked (more like quadruple-checked!) all of the connections, resistor values, etc. using the method described elsewhere on this site (i.e., using a highlighter to mark off connections after verifying that they're correct). I've also gone through all of the links on this page https://el34world.com/Forum/index.php?topic=19361.msg199897#msg199897 in my effort to troubleshoot. I'm ready, willing, and able to review any additional information, but I thought I'd let everyone know that I have done some due diligence prior to posting. ;)
The issue is this: With the tubes NOT installed, I'm not seeing high voltage on pins 1 or 6 of my 12ax7 (Tung-Sol reissue) preamp tubes. I am, however, seeing high voltage to pins 3 and 7 of the EL84 power tubes (also Tung-Sol). Does this scenario suggest any obvious issue that someone new to amp circuits might miss?
Online sluckey
Re: Not Seeing High Voltage in Preamp Tube Pins
« Reply #1 on: April 06, 2021, 09:01:53 am »
Do you have a 22K resistor installed between points Y and Z? Is point Z accidentally grounded? Check for resistance between point Z and chassis. Must not be low resistance.
Pin 3 is the cathode and must not have high voltage applied. Pins 7 and 9 are the only pins that should have high voltage present.
Pictures would be very helpful.
Offline Matt-O
« Reply #2 on: April 06, 2021, 09:22:20 am »
Thanks for the reply, sluckey! I actually meant pins 7/9 on the power tubes - that was pre-coffee:)
I do have a 22k 3-watt resistor between points Y and Z, and I'm seeing 9.6k ohms between Z and chassis. Is that considered low resistance in this context?
Online sluckey
« Reply #3 on: April 06, 2021, 09:31:26 am »
The resistance should be very high, hundreds of KΩ or MΩ. Unsolder the positive lead of that 22µF cap that's attached to the point Z buss. Does resistance go way up?
Offline Matt-O
« Reply #4 on: April 06, 2021, 09:36:49 am »
Here are a few photos (I'd be happy to take more):
Offline Matt-O
« Reply #5 on: April 06, 2021, 09:37:26 am »
And a few more pics...
Offline Matt-O
« Reply #6 on: April 06, 2021, 09:42:22 am »
Unsoldered the positive lead of the 22uF cap and checked the resistance. It actually went down to 2.3 Ohms.
Online sluckey
« Reply #7 on: April 06, 2021, 09:55:51 am »
I see the problem. See pic...
Offline Matt-O
« Reply #8 on: April 06, 2021, 09:58:59 am »
Doh, how did I not see that?! Thank you so much for the assist!
Offline Matt-O
« Reply #9 on: April 06, 2021, 10:16:03 am »
Well, I moved the black wire to the proper turret connection. I also replaced that 22k/3w resistor. Looks like that 22k resistor is still getting really hot - the color bands have already darkened like on the previous resistor.
Also, still no high voltage to the preamp pins.
Online sluckey
« Reply #10 on: April 06, 2021, 10:39:02 am »
Repeat everything you just did. I'm betting there is still a ground on that Z buss.
Offline Matt-O
« Reply #11 on: April 06, 2021, 12:07:45 pm »
Will do.
My ignorance might be showing here, but aren't there multiple pathways from the Z bus to the main ground (see pic)?
Offline PharmRock
« Reply #12 on: April 06, 2021, 12:15:58 pm »
Is your under-the-board ground wire for the filter caps in the right place?  Sometimes when flipping the board over and doing the under-board wires, its easy to put them on the wrong side.  could the ground wire be on the (+) of the filter caps instead of the (-)?
Offline Matt-O
« Reply #13 on: April 06, 2021, 12:24:40 pm »
This is possible. I did check the under-the-board wires before I installed the board, but it's possible I wired it incorrectly. I'm going to check that tonight when I get home from work.
Online sluckey
« Reply #14 on: April 06, 2021, 12:44:16 pm »
Apparently there are in you amp! But there should be ZERO paths to ground in a properly wired amp. I already told you what resistance you should measure. Keep looking. There's at least one more duh huh in there.
Offline Matt-O
« Reply #15 on: April 06, 2021, 08:41:12 pm »
Ok, checked the under-board connections, and they're all correct. I verified this by testing continuity between the corresponding turret points on top of the board.
One thing I noticed when I was doing some continuity checks is that I'm getting continuity between the 22uF cap that connects to the Z buss; I don't think I should be. Think it might be a bad cap, which would explain how the Z buss is connected to ground.
Online sluckey
« Reply #16 on: April 06, 2021, 08:54:13 pm »
Well, unsolder the positive lead and see if your resistance between Z and chassis goes way high.
Offline Matt-O
« Reply #17 on: April 06, 2021, 10:46:52 pm »
I believe I've figured it out! I think the Z buss wires were in contact with a screw that holds the turret board to the chassis. I had covered the screw with two layers of electrical tape, but the buss wire seems to have been in contact with it somehow. I moved the buss wire up toward the top of the turrets on either side of the mounting screw and voila - high resistance at Z, no more ground on the Z buss, and I'm seeing high voltage at pins 1/6 of my preamp tubes.
Online sluckey
« Reply #18 on: April 07, 2021, 08:12:39 am »
Haha. I had to blow that pic up really big to be able to see that tape. Good job. A nylon screw might be a good idea.
Offline Matt-O
« Reply #19 on: April 07, 2021, 08:15:29 am »
A nylon screw would have been a great idea. If it becomes a problem down the road, I'll switch it out.
Thanks so much for your help! I feel like I know a little bit more about this circuit and how to troubleshoot.
