August 29, 2026, 07:33:29 pm
Hoffman Amps Forum image Author Topic: Silvertone 1484 Reverb going on and off  (Read 4842 times)
Offline jimlat
« on: April 07, 2021, 08:07:58 am »
I recently took my 60's Silvertone 1484 amp out to use it after many years. When I turned it on I was getting a bad "hum". I replaced all the original tubes with new ones. The hum went away. But now the reverb keeps going on and off as I play. When I "tap" on the top of the amp head, it comes back on. When I replaced the tubes I sprayed all the pins with CRC Tuner cleaner and moved them in and out a few times. But now I'm reading that the best product to use is DeOxIt D5 so I ordered a can. Does anyone have any suggestions as to what may be wrong and what else I should try? Any input and advice would be greatly appreciated.
Offline Soulfetish
Re: Silvertone 1484 Reverb going on and off
« Reply #1 on: April 07, 2021, 08:39:51 am »
I'm willing to bet you're getting intermittent contact in the tube socket. Silvertone's have notoriously bad tube sockets.
You can try and wiggle the 6CG7 around in the socket a little to see if that is the issue. If it is, I would first try and spray out the socket with Deoxit. If that doesn't seem to work, you might want to re-tension the socket terminals. But in my experience, the socket often needs to be replaced.
Offline jimlat
« Reply #2 on: April 07, 2021, 02:38:38 pm »
How is the DeOxIt D5? Everybody is telling me to buy it. Does it work better then the other brands like CRC?
« Last Edit: April 08, 2021, 09:41:06 am by jimlat »
« Reply #3 on: April 07, 2021, 08:14:15 pm »
I would be surprised if it's the tube socket.  The Dan Electro amps often used a piezo type reverb and those were pretty flimsy in my opinion and my bet is you may have a short within
that piezo type reverb circuit .
IF you are experienced and know how to work on amps safely, you might consider replacing the Dano reverb with a one tube reverb.  I did that on my Dan Electro Centurian 275 and it turned out great.
Looking at the back of a 1484 cab head, you will see the piezo type reverb "pan" right behind the preamp tubes. I am wondering if you tap gently on that with a non conductive stick like a wooden chop stick if it will reveal it coming on/off?
« Last Edit: April 07, 2021, 08:18:13 pm by tubenit »
Offline scstill
  • https://stillampd.com
    • Still Amp'd
« Reply #4 on: April 08, 2021, 12:20:48 am »
I rebuilt my 1484 reverb successfully.
It works great. I like it alot.
https://el34world.com/Forum/index.php?topic=26510.msg290174#msg290174
Offline terminalgs
« Reply #5 on: April 09, 2021, 05:10:38 am »
Plate resistors on the tank driver triodes on 1484s are undersized for the wattage rating. Dano used 1/2W but really needed 1W.
See voltages on schematic. Voltages show 0.5W or 0.6W (can't remember precisely).
Might be your problem if one is failing or failed.
