September 08, 2026, 08:08:30 pm
Hoffman Amps Forum image Author Topic: Math help  (Read 7790 times)
Math help
« on: April 10, 2021, 05:58:14 pm »
I have a "leftover" helium tank, basically 4' X 8"  (calculated Volume using 45")
the internet tells me Vol = .037067 M^3
what the ducks can't find;
the gas is at 2,000psi, I want it at atmosphere @ sea level
I have the density of He  .179Kg/M
Got air at 1.29Kg/M
my endgame is to know, on a napkin, what the "lift" of my unknown volume can move with initial acceleration  at 0
thanks
dave
Offline acheld
Re: Math help
« Reply #1 on: April 10, 2021, 09:19:38 pm »
Medical(for MRI machines, usually )?   Helium Trimix (eg welding gas, about 90 %)?  Grade 5 (diving, usually 5000ppm or less impurities )?   Balloon grade( about 80%)?
Going for a suborbital flight, are we?
If temp is constant, P1*V1=P2*V2:   2000psi * 37 liters = 14.9 psi * X liters
So you have about 5 m^3 of gas, or about 175 ft^3.
Lifting coefficient of helium is about 1.1kg/m^3, so you could lift about 12 pounds.   Seems like it should be more.
That's my napkin, sans the ketchup I just spilled.
Re: Math help
« Reply #2 on: April 11, 2021, 07:46:12 am »
thanks!!! :thumbsup:
I was guessing <20lb
thinking once friction  and static weight is overcome maybe more, but your napkin value is good by me!
I'll keep to the ground, let my sUAV do the flying.
n ya 5 9's gas but i'm not that picky  :icon_biggrin:
