September 16, 2026, 02:37:41 pm
Hoffman Amps Forum image Author Topic: Hot Rod Deluxe switch issue  (Read 4622 times)
Offline gfj
« on: April 13, 2021, 02:42:49 am »
Hi , first time poster and first time repairer of a HRD rev A
First thing done was to replace 3 resistors and 2 zeners , then hard wire the connections to restore some integrity to a heat damaged board.
This is a 2007 build with a 1970's single sided 1 oz copper pcb---WTF.
What i did notice was:
In  normal mode (off) : yellow light on
In  drive    mode        : yellow light on
In  more drive mode   : red light on
Here are the test point readings :  Readings in brackets are from schematic for a rev A Jan 2001
TP31  normal       : + 1.04v (+1.39v)
         drive          : + 1.04v (+1.08v)
         more drive  : + 1.04v (+1.08v)
TP32  chn sel out     : + 0.56v (+0.536v)
         chn sel in        :+ 9.60v (+9.69v)
TP33  normal           : - 13.6v (+16.0v)
         drive              : - 13.6v (- 13.0v)
         more drive      : - 14.0v (- 13.5v)
TP34  normal           : - 4.8v   (- 12.5v)
         drive              : - 4.8v   (- 4.9v  )
         more drive      : - 4.36v (- 4.14v)
TP35  more drive out : - 0.54v (- 0.52v)
         more drive in   : - 9.35v (- 9.92v)
TP36  normal            : - 15.8v (- 15.5v)
         drive               : - 15.8v (- 15.4v)
         more drive       : +17.4v (+16.0v)
Can anyone shed some light on this issue.
« Last Edit: April 13, 2021, 04:33:41 am by gfj »
