September 16, 2026, 05:05:53 am
Hoffman Amps Forum image Author Topic: Help me Mod this 6G16 Vibroverb Build!  (Read 7336 times)
Offline waldner
  • I REALLY DO love tube amps
« on: April 14, 2021, 05:10:58 pm »
I'm building a '63 Brownface Vibroverb clone and thought it might make sense to incorporate some changes as I build it. From what I can tell, the normal channel is less useful than the bright channel- much like on the Blackface amps.
Can anyone who is better at reading schematics and converting them to layouts help recommend some parts changes to do something different with the normal channel? Also any other changes you might make to improve anything? Better, deeper tremolo? Reverb improvement? Or leave those as is?
Here are links to the 6G16 Schematic and Layout:
https://www.mojotone.com/Amp%20Kit%20Schematics%20and%20Wiring%20Diagrams/Brownface/Vibroverb_6G16_WD.pdf?vid=wzfIDMvQAiXxIBqi&shipmeth=50031&chrole=17&sj=p1lcpd5ZK5ZHq6993QdGc9t1e%3B1618427618%3B777049000&ck=07JUgsvQAiTxIHjW&promocode=&cktime=184548&gc=clear&cart=1483068&promocodeaction=overwrite
https://www.mojotone.com/Amp%20Kit%20Schematics%20and%20Wiring%20Diagrams/Brownface/Vibroverb_6G16_SCH.pdf?vid=wzfIDMvQAiXxIBqi&shipmeth=50031&chrole=17&sj=p1lcpd5ZK5ZHq6993QdGc9t1e%3B1618427618%3B777049000&ck=07JUgsvQAiTxIHjW&promocode=&cktime=184548&gc=clear&cart=1483068&promocodeaction=overwrite
Re: Help me Mod this 6G16 Vibroverb Build!
« Reply #1 on: April 14, 2021, 05:24:05 pm »
build as is,  then after a week or so of playing, you'll be better informed on what needs tweaked
Offline waldner
« Reply #2 on: April 14, 2021, 06:21:05 pm »
I would build as is and then mod later, but I've done that many times.  I have so many amps (kind of an addict/amp hoarder) and already know that I'll want the change the normal channel to do something different.  I think you may be right about the tremolo and reverb though as they are characteristic of the brown era sound and worth trying as is.
In all of the demo videos and clips, everyone uses the bright channel only.  Seems just like with the AB763 amps where you might as well change it up a bit for the 'unused' channel.  I'm not sure if the reverb and tremolo work on the normal channel in the stock build?  I'm guessing not?  It might be nice to make them work for both channels?
« Reply #3 on: April 14, 2021, 06:50:27 pm »
I used the 5F6A tone stack cap values on the normal channel of my '67 Bandmaster. Sounds a little different but I'm not really impressed. Easy to do.
The reverb only works on the bright channel but the Tremolo works on both channels since it wobbles the grids of the output tubes. You will most likely have a difficult time getting good tremolo and a satisfactory bias setting when using 6L6s. There a trem mod sheet somewhere in Hoffman's library that deals with getting a stronger tremolo. Not easy to find but the search will build character.   :icon_biggrin:
Offline waldner
« Reply #4 on: April 14, 2021, 07:54:51 pm »
Is this the page you are talking about?  https://el34world.com/Hoffman/files/Hoffman_AB763_Mods.pdf
Also it looks like the schematic I linked above from Mojotone has the tremolo applied to a 12AX7.  Maybe they like that method better than affecting the bias of the output tubes?
« Last Edit: April 14, 2021, 08:28:40 pm by waldner »
« Reply #5 on: April 14, 2021, 07:59:22 pm »
That's it! How did you find it so fast? I can never find it unless I'm looking for something else.  :l2:
Offline waldner
« Reply #6 on: April 14, 2021, 08:30:40 pm »
Ha!  I started searching immediately.  See my question just above about the Mojo schematic which looks like tremolo is being accomplished with a 12AX7 and may not need much ‘fixing’?
« Reply #7 on: April 14, 2021, 09:04:07 pm »
No. The Mojo trem osc is connected to a cathode follower which in turn wobbles the bias of the output tubes. The Mojo 6G16 and the Hoffman AB763 trem circuits are identical. That's because Hoffman's AB763 is not a pure breed. His AB763 used the 6G16 bias vary tremolo, rather than the optocoupler used in a real Fender AB763.
Offline waldner
« Reply #8 on: April 15, 2021, 12:21:29 am »
Ok, I see.  So the good news is your mods page I found can help increase the trem if it's weak?
« Reply #9 on: April 15, 2021, 07:10:21 am »
Yes. The LED mod is the most effective.
Offline Bieworm
  • I like it loud!
« Reply #10 on: April 15, 2021, 12:05:49 pm »
I've had the custom vibrolux reverb, which is basically a hotrod 63 vibroverb. That trem was amazing!!! And so amazing I converted my opto trem vibro king into bias vary trem.. both 6L6 amps. No amp has deeper trem than those..
And at any bias setting it's strong. I think it was tubeswell that helped me on that one. It took some cap tweaking to get it deep and right
« Last Edit: April 15, 2021, 12:07:53 pm by Bieworm »
Offline waldner
« Reply #11 on: April 15, 2021, 06:21:30 pm »
Cool.  Good to know it has the potential to be deep and swampy.
