August 30, 2026, 08:02:01 pm
Hoffman Amps Forum image Author Topic: power transformers for 6SN7-KT88 PP  (Read 4613 times)
Offline pc1093
« on: May 04, 2021, 11:35:08 pm »
Hi All,
I got a diagram about 6SN7-KT88 PP. I find that 4XKT88 I(f) need 6.4A and 4X6SN7 I(f) need  2.4A.
However, the diagram showing that the transformers got 6.3V @ 5A.
1. Is the transformer only work for one channel?
2. are there any power transformers that support both channels in one?
Offline Latole
Re: power transformers for 6SN7-KT88 PP
« Reply #1 on: May 05, 2021, 03:30:02 am »
This power supply (can only) feed one channel. We see 2 X KT88 and 2 X 6SN7
Hammond transformers don't have one PT to do the job of  two PT you need.
Their bias voltage are too low. You have to tap bias on H.V winding.
https://www.hammfg.com/electronics/transformers/classic/300?referer=787
« Last Edit: May 05, 2021, 03:40:43 am by Latole »
« Reply #2 on: May 05, 2021, 02:18:09 pm »
for two channels use hammond 379WX will work for 2 channels, however, you will need to change the B+ rectifier to full wave rather than a bridge.
Offline pc1093
« Reply #3 on: May 05, 2021, 10:48:58 pm »
if i use one power transformer,such as hammond 379WX, need i change the choke to 10H@1A?
« Reply #4 on: May 06, 2021, 03:26:33 am »
yes.
