September 08, 2026, 07:18:07 pm
Hoffman Amps Forum image Author Topic: Automated dust vacuum-blast gate system  (Read 8103 times)
« on: May 09, 2021, 08:02:44 am »
Check out my automated dust vacuum-blast gate system.
Partial BOM
« Reply #1 on: May 09, 2021, 09:13:59 am »
These are some of the parts I used for this project
Pneumatic cylinder - Model  CDJ2B - Bore 10mm x 50mm stroke
Available on Amazon and many places, but I bought mine on Ali Express
https://www.aliexpress.com/item/32992592636.html
https://www.amazon.com/dp/B07TT5Z48T
Air filter - Pressure regulator
https://www.amazon.com/dp/B07STNLFMS/
4mm tubing
https://www.amazon.com/dp/B077WD6NVN
https://www.amazon.com/dp/B07RK4MCKP
4mm fittings x 4
https://www.amazon.com/gp/product/B01N6JF205
3/8" tubing kit
www.amazon.com/dp/B07RTB9K9N/
1/8" NPT 5 Way 2 Position Pneumatic Electric Solenoid
https://www.amazon.com/dp/B00YCWL9I4
Current sensor
https://www.amazon.com/dp/B01LWN37KS/
1/4" Hose Barb to 1/8 NPT Male Brass Coupler fitting
https://www.amazon.com/KOOTANS-Brass-Coupler-Fitting-Quick-Connect/dp/B07P962KXQ/ref=sr_1_3
These were used to drill and tap 5mm threads so that the 4mm fittings could screw into the Pneumatic Solenoid
Hex Head Plug, 1/8" NPT Male
https://www.amazon.com/Legines-Brass-Pipe-Fitting-Head/dp/B074JZQWXC
Relay board
https://www.amazon.com/dp/B06XRYGM2C/
« Last Edit: May 11, 2021, 02:17:06 pm by EL34 »
Re: Automated dust vacuum-blast gate system
« Reply #2 on: May 09, 2021, 09:14:09 am »
Some images
« Last Edit: May 11, 2021, 02:17:44 pm by EL34 »
« Reply #3 on: May 11, 2021, 02:26:46 pm »
« Reply #4 on: May 11, 2021, 02:27:34 pm »
