June 16, 2026, 12:16:28 pm
Hoffman Amps Forum image Author Topic: power TX w/o center tap and tremolo  (Read 3743 times)
Offline isaac_teller
« on: May 12, 2021, 01:12:19 pm »
Hello again. I'm building a Blackface Deluxe clone. The power TX doesn't have a center tap(full wave bridge rectifier). I have no problem obtaining the bias voltage from one leg of the AC secondary but how would I implement the tremolo? Thank you.
http://www.prowessamplifiers.com/schematics/fender/deluxe_reverb_ab763_schem.pdf
Re: power TX w/o center tap and tremolo
« Reply #1 on: May 12, 2021, 01:16:51 pm »
What do you perceive to be the sticking point?
« Reply #2 on: May 12, 2021, 01:27:40 pm »
There's no 50 volt tap. I'm using this bias circuit. Everything works out except the cap connected to the 2M2 resistor
http://www.valvewizard.co.uk/cap_coupled_bias_supply2.jpg
« Last Edit: May 12, 2021, 01:30:32 pm by isaac_teller »
« Reply #3 on: May 12, 2021, 02:05:11 pm »
Take that feed from the raw bias supply, the -ve end of C2.
« Reply #4 on: May 12, 2021, 02:21:20 pm »
Thank you very much
