August 29, 2026, 07:32:58 pm
Hoffman Amps Forum image Author Topic: Why does the JCM800 use a coupling cap before the power section?  (Read 6642 times)
Offline markmalin
  • Malin Sweet Loraine
    • Malin Amplification
Using Robinettes JCM800 schematic, there's a 0.022uf coupling cap between the input of the phase inverter and the master volume.  I'm wondering why this is needed if the caps in the tone stack block all the DC already.  Is this additional cap redundant, or is it used for tonal reasons?
Thanks guys!
Mark
"... there are Flying V's and then there are the ones shaped like peanuts..."  - my son at age 9
Offline glass54
Re: Why does the JCM800 use a coupling cap before the power section?
« Reply #1 on: May 12, 2021, 11:04:57 pm »
Hi Mark
DC isolation for Pot. Bias on Grid (V3A) 24V will be severely compromised.
This would vary with pot position, esp when pot wiper is closer to Ground.
The 22nF Cap also sets the Lower Freq break point for that section of circuit.
Pots also don't like DC on them esp Carbon (adds a little unwanted Fx  :laugh:)
Kind regards
Mirek
"To measure is to know"
Offline 2deaf
  • Now too deaf for 100 watts
« Reply #2 on: May 13, 2021, 12:32:38 am »
All long-tailed pairs like this have a capacitor in that position.  They won't work without it.
The grid doesn't really have 24V on it.  Well, it does when you put a meter on it, but it has 36.5V on it as soon as you remove the meter.
The input impedance of that LTP PI is higher than it looks so that the .022uF cap passes all audio frequencies.  No tonal reason there.
« Last Edit: May 13, 2021, 12:39:18 am by 2deaf »
Offline glass54
« Reply #3 on: May 13, 2021, 12:40:44 am »
Additional useful info:
https://www.aikenamps.com/index.php/the-long-tail-pair
It's a good read and I'm sure there are others.
Kind regards
Mirek
Offline markmalin
« Reply #4 on: May 13, 2021, 08:42:57 am »
Thanks, guys.  That helps.  And I'll read that article from Aiken.  Thanks
So if I have a single ended output stage (no phase inverter), is a cap still needed?  Here's a schematic I'm working with.  I guess at the end of the day I'm wondering if I should put a coupling cap in my circuit between the grid of the EL34 and the master like the Marshall schematic.
« Reply #5 on: May 13, 2021, 08:54:17 am »
It's not a question of phase inverter or no phase inverter. The question is "Does the grid operate with a voltage other than zero?" If yes, then a cap is required.
No cap is required between your EL34 grid and the MV. In fact, if you put one there, the EL34 will not work properly.
Offline markmalin
« Reply #6 on: May 13, 2021, 09:45:20 am »
I see.  Thanks for the explanation, slukey. When I fired up the amp for the first time I measured the voltage at the grid of the EL34 because I was trying to understand.
