August 29, 2026, 07:29:55 pm
Hoffman Amps Forum image Author Topic: cee jay11 amp voltages  (Read 5448 times)
Offline Mungo Park
« on: May 14, 2021, 04:19:38 pm »
I am wanting to build a cee jay 11 by Devide by 13.
I have the schematic but it has no voltages on it.
Would anybody have the voltages for this amp.
What I would really need is the voltages on the plates.
Re: cee jay11 amp voltages
« Reply #1 on: May 14, 2021, 05:01:01 pm »
Why do you need plate voltages? The PT voltages are listed. Just use that PT, build the amp, measure voltages after the fact.
« Reply #2 on: May 14, 2021, 05:04:52 pm »
also guessing it's a "proven" design
Offline Mungo Park
« Reply #3 on: May 14, 2021, 05:10:40 pm »
Thanks for the answer, very simple and easy to follow instructions.
                           Cheers Ron
Offline pullshocks
« Reply #4 on: May 14, 2021, 05:45:00 pm »
There have been a few builder reports of success.  As I recall, DarkBlueMurder was one.  I have breadboarded it, and it sounded good.
Edit--you might want to leave room in your layout for PI grid stopper.
« Last Edit: May 14, 2021, 05:50:07 pm by pullshocks »
Offline Mungo Park
« Reply #5 on: May 14, 2021, 08:40:12 pm »
I have herd some good things about this amp, which is what attracted it to me, I have a fender selection so this should be a little different.
 Looking at my power transformers. the closest I have is 330 0 330 but i guess I can figure out a filter cap/resistor combo to compensate for a higher starting voltage.
« Reply #6 on: May 14, 2021, 08:48:27 pm »
Bad idea IMO.
Offline Mungo Park
« Reply #7 on: May 15, 2021, 09:32:25 am »
Well I was thinking if I used. 5y3 rectifier tube this would drop me down to a more compatible voltage which would still need some adjustments
