September 15, 2026, 12:01:50 am
Hoffman Amps Forum image Author Topic: Traynor bass amp running hot/bias resistor  (Read 5015 times)
Offline Diverted
« on: May 21, 2021, 09:59:32 am »
Hi,
How would I increase the negative bias in this Traynor bass amp? It's non-adjustable fixed bias and currently the 6AC7s are running at about 80 percent. Would I want to reduce the 33K (R32) just prior to the bias diode, or would I be better off adjusting the 47K (R31) after the diode? Thanks.
Re: Traynor bass amp running hot/bias resistor
« Reply #1 on: May 21, 2021, 10:16:31 am »
Put a 50K pot in series with that 47K.
Offline Diverted
« Reply #2 on: May 21, 2021, 10:48:43 am »
Can't do a pot on this one, he doesn't want it. So instead, I guess just try upping the value of that resistor ... maybe 51K, 56K, etc.? Thanks for the tip.
« Reply #3 on: May 21, 2021, 10:57:13 am »
Tell him that he may have to go through this every time he changes tubes unless he submits to the pot.   :icon_biggrin:
Changing the value of a resistor is just as much a mod as adding a trim pot.   :think1:
Offline 2deaf
  • Now too deaf for 100 watts
« Reply #4 on: May 21, 2021, 11:03:42 am »
My money is on 51K.
36K in series with a 25K pot if you want to go that route.
