September 15, 2026, 03:30:13 pm
Hoffman Amps Forum image Author Topic: Musicmaster amp with fixed bias  (Read 4846 times)
Offline isaac_teller
« on: May 25, 2021, 12:28:44 pm »
Hello. I have a Fender Musicmaster amp with 6V6 tubes. It's about 10 watts. I would like to give it a bit more punch without investing an excess amount of money(For example putting in larger power and output transformers that can handle 6L6 tubes). Is it possible to remove the 220 ohm cathode resistor, ground the cathodes, add a bias circuit with the bias voltage going to the center tap of the interstage transformer? Thank you.
http://www.prowessamplifiers.com/schematics/fender/musicmaster_bass_schem.pdf
Re: Musicmaster amp with fixed bias
« Reply #1 on: May 25, 2021, 01:46:55 pm »
Sounds feasible. I would convert to fixed bias with the 6V6s first since there's little money involved. Get that working and evaluate. Only then would I start throwing money at it.   :icon_biggrin:
« Reply #2 on: May 25, 2021, 01:58:11 pm »
If Fender coulda, they woulda. But usually you get what you pay for (or less).
It's about 12% more power, 0.5dB. I don't think you could tell the difference in a dark club.
« Reply #3 on: May 25, 2021, 02:43:01 pm »
Thank you.
