September 20, 2026, 10:07:27 am
Hoffman Amps Forum image Author Topic: Question about g1 circuit resistance  (Read 4838 times)
Offline Craftyjam
« on: June 04, 2021, 02:21:05 pm »
Hello, first post  :icon_biggrin:
I would like to know if an attenuating resistor adds to the circuit resistance of g1, and if so, how far the maximum circuit resistance can be safely exceeded.
Here is a picture of what I'm working with. Building a simple SE guitar amp that due to design constraints is more prone to oscilation. It sounds pleasing to me when using this attenuating circuit, but I do not wish to damage my tubes.
Thanks!
Re: Question about g1 circuit resistance
« Reply #1 on: June 04, 2021, 04:31:54 pm »
... I would like to know if an attenuating resistor adds to the circuit resistance of g1, and if so, how far the maximum circuit resistance can be safely exceeded.
Here is a picture of what I'm working with. ...
The grid circuit resistance is pretty much what can be measured with your meter, the resistance between the control grid and its cathode.
As the max possible anode dissipation in the circuit decreases, then it’s safe to increase the grid circuit resistance.
Note that almost no fixed bias valve guitar amps abide by the 100k grid circuit resistance limit of many valve types.
Offline brewdude
« Reply #2 on: June 04, 2021, 04:53:09 pm »
I had an amp build that was not pleasing me many years ago and in an attempt to improve it, I tacked some resistors across the existing grid leaks to give a total of ~100k instead of 250k.  I thought it helped this amp.  In fact I’ve used the recommended limits at the grid leaks in 3 or 4 amps since.  I’m not saying it’s necessary or better or worse, I just thought I’d share.
« Reply #3 on: June 04, 2021, 05:18:12 pm »
Welcome.
That plan shows 221.5k to the tube. Without knowing the tube type or bias system we can't say if that is OK.
Offline Craftyjam
« Reply #4 on: June 04, 2021, 05:51:30 pm »
Ah ok, so the total grid resistance is comprised of the grid stopper and the the grid leak, and not the attenuating resistor as well.
The power tube is a 6AQ5 and the datasheet states that the max g1 circuit resistance is 500kohm when using cathopde bias, which I am.
Thank you for clearing that up.
