September 14, 2026, 06:48:54 pm
Hoffman Amps Forum image Author Topic: p2pAmps Bad-Dawg comin at ya  (Read 13324 times)
Offline p2pAmps
    • p2pAmps
« on: June 23, 2021, 05:51:16 pm »
This is a single channel AB763-ish with added presence control and a good ole 3 knob verb (Dwell, mix, tone) and no trem circuit.  I also added an attenuator of sorts as this bad boy is hot in the frontend.  So far I have built about a dozen and I think we have a good one here from the reports.  Thought I would share with your guys.
Note: the music playing through it is my pal Travis Toy as it's hard to test things with a guitar in my hand (plus I suck)
Cheers
Everything Affects Everything
Offline jordan86
Re: p2pAmps Bad-Dawg comin at ya
« Reply #1 on: June 23, 2021, 07:17:00 pm »
Gorgeous. That’s an amp I’d love to build. Similar to a Dr Z EZG50 but with twice the power I imagine?
« Reply #2 on: June 23, 2021, 07:41:03 pm »
Want to share the schematic?
Offline p2pAmps
    • p2pAmps
« Reply #3 on: June 23, 2021, 07:47:33 pm »
Yeah if I had one LOL.  I need a master like you to draw me one up "hint hint"
« Reply #4 on: June 23, 2021, 08:21:45 pm »
I might could do that. Need a lot more than a short video though.
Offline p2pAmps
    • p2pAmps
« Reply #5 on: June 23, 2021, 08:22:57 pm »
I'll shoot you a call Steve...
« Reply #6 on: June 24, 2021, 01:31:56 am »
Something like an Allen Old Flame?
Offline p2pAmps
    • p2pAmps
« Reply #7 on: June 24, 2021, 06:07:33 am »
[/quote]
I'm not sure as I have never looked at any Allen amps.  I know who David is however and he certainly has a great reputation with his stuff.
« Reply #8 on: June 24, 2021, 07:16:10 am »
Sounds like Alabama Jubilee. Whatever you are building there is hardly ill concieved.  Now PTP, just incase you can use this amp with a telecaster, there are some very cool links here.  Brent cannot sing, but he doesn't need too.
Offline p2pAmps
    • p2pAmps
« Reply #9 on: June 24, 2021, 07:20:50 am »
Sounds like Alabama Jubilee. Whatever you are building there is hardly ill conceived.  Now PTP, just in case you can use this amp with a telecaster, there are some very cool links here.  Brent cannot sing, but he doesn't need too.
Hey Ed!  Brent can certainly play that Tele huh :). Did some work on some of his gear and he is a great guy as well.  Good times
« Reply #10 on: June 24, 2021, 07:25:22 am »
That he is.  I couldn't believe it when I was introduced to him.  I knew the name and all his work to that point, but I thought he would be hip, you know.  Naw, he is nerdier than me and you put together.
« Reply #11 on: June 24, 2021, 07:28:53 am »
Now what it the "Attenuator?" A master volume of some sort?
Offline p2pAmps
    • p2pAmps
« Reply #12 on: June 24, 2021, 07:32:26 am »
Same sort of effect Ed.  It really is a way to back off the pre-amp section where it ties to the power section.  This amp has a hot front end and is just so loud.  I pulled the 220K mix resistor and added a 250K pot as a test and it worked out really nice without changing the sound of the amp at all.  That being said I decided to incorporate into all future Bad-Dawgs and have added to most of the existing ones I have built (about a dozen or os)
« Reply #13 on: June 24, 2021, 07:35:53 am »
Said another way, it's a pre PI MV, just slightly different from this...
     http://sluckeyamps.com/tdr/tdr.pdf
« Reply #14 on: June 24, 2021, 07:51:33 am »
I got ya!  I know you have sold these because I am a you tube stalker.  I was thinking you would want to stay clean being made to play Pedal Steel.
Offline p2pAmps
    • p2pAmps
« Reply #15 on: June 24, 2021, 07:53:43 am »
Yes I had steel guitar in mind with this but turns out it's a pretty good guitar amps as well if you want that loud and clean thing.  I use pedals anyway so it works for me.
« Reply #16 on: June 24, 2021, 08:00:21 am »
Yea, well, you probably good enough to play clean, but I have heard some string nasty sustaining guitar sounds coming from your fingers through a Princeton, but you do have the Nashville Studio geetar players secret weapon. I got one too.  The green Chinese overdrive.
« Reply #17 on: June 24, 2021, 08:01:56 am »
BTW,  When did you finally turn off your Weller?
Offline p2pAmps
    • p2pAmps
« Reply #18 on: June 24, 2021, 08:07:55 am »
I just leave it on LOL
« Reply #19 on: June 24, 2021, 12:48:21 pm »
I see the half power switch is not connected. What are your intentions? How will you connect it?
Offline p2pAmps
    • p2pAmps
« Reply #20 on: June 24, 2021, 01:09:17 pm »
Yeah it’s connected steve
« Reply #21 on: June 24, 2021, 03:15:05 pm »
OK, so is it simply switching a pair of 6L6 cathodes in/out? Something else?
« Reply #22 on: June 24, 2021, 03:17:45 pm »
Also, what value filter caps and dropping resistors? Can you open the doghouse and take a hi-rez pic?
Offline p2pAmps
    • p2pAmps
« Reply #23 on: June 24, 2021, 03:33:47 pm »
Caps are 2-100uF/350v and 3 22uF/450 F&Ts and dropping resistors are 3 watt 1K and 4.7K
Offline p2pAmps
    • p2pAmps
« Reply #24 on: June 24, 2021, 04:20:21 pm »
Here you go
« Reply #25 on: June 24, 2021, 04:35:51 pm »
Does this look like your power supply?
Did I get the PT primary wiring right?
Is the STBY switch in the right place?
Are you using 220K/1W balance resistors across the two series 100µF caps?
Tell me about your half power switch and how it's connected.
Offline p2pAmps
    • p2pAmps
« Reply #26 on: June 24, 2021, 04:42:11 pm »
Did I get the PT primary wiring right?  Yes sir
Is the STBY switch in the right place?  Yes
Are you using 220K/1W balance resistors across the two series 100µF caps?  Yes but using 2 watt
Tell me about your half power switch and how it's connected.  1/2 power dumps ground on V5 and V8
Offline p2pAmps
    • p2pAmps
« Reply #27 on: June 24, 2021, 04:43:28 pm »
Also Steve, not using the filament center tap, using 2 - 100Ω to ground artificial center tap off the pilot
Offline acheld
« Reply #28 on: June 24, 2021, 06:49:58 pm »
Curious:  How did you decide to use artificial center taps on the heaters rather than the filament center tap?
Offline p2pAmps
    • p2pAmps
« Reply #29 on: June 24, 2021, 08:50:54 pm »
Because my PT doesn't happen to have a center tap for the filament windings :)
Cheers
« Last Edit: June 24, 2021, 09:03:48 pm by p2pAmps »
Offline p2pAmps
    • p2pAmps
« Reply #30 on: June 28, 2021, 04:03:27 pm »
Here is another Bad-Dawg I built over the weekend.  I get to keep this one for me finally!
Also, big shout out to Sluckey for drawing me up a very nice schematic for this amp, the man knows his stuff I can tell you that.
Cheers
« Reply #31 on: June 28, 2021, 04:20:04 pm »
Looks exactly like the other one. Even gat a green gator clip lead on the same PT bolt!    :icon_biggrin:
Offline p2pAmps
    • p2pAmps
« Reply #32 on: June 28, 2021, 04:21:09 pm »
I like to be consistent cause I know you're watching!  This one has PRP resistors and grey zip ties too
