September 20, 2026, 02:23:37 am
Hoffman Amps Forum image Author Topic: Speaker Feedback Inpedance Sensitive?  (Read 5043 times)
Offline jrc111
« on: June 23, 2021, 06:41:28 pm »
I have a Hot Rod Deville 212 overdue for a recap, and I’d like to put a multi-tap Output XFMR in it while it’s down, to take advantage of some extension cabs I have.  In the circuit below, the gray wire is the “feedback” lead, tapped into the 4 ohm XFMR output.  Any problem leaving that as is, and putting multiple jacks: 2, 4, 8, and 16    ohms, and power off, just plug in what I’m using, and leave the feedback wire where it is?
Re: Speaker Feedback Inpedance Sensitive?
« Reply #1 on: June 23, 2021, 06:52:48 pm »
« Reply #2 on: June 23, 2021, 06:53:58 pm »
The feedback wire should always connect to the 4Ω output, regardless of which impedance jack you connect speakers.
Offline jrc111
« Reply #3 on: June 23, 2021, 08:23:00 pm »
Thanks!  I’m going to use the same scheme for a Hoffman Princeton Reverb I’m collecting the parts for, and thought I’d try this first.
Offline thetragichero
« Reply #4 on: June 23, 2021, 11:26:24 pm »
just adding this so you know the why: https://www.aikenamps.com/index.php/designing-for-global-negative-feedback
long story short, you could attach it to a different tap, but then would need to change the nfb values to achieve the same sound/response
« Reply #5 on: June 24, 2021, 01:04:41 pm »
..., you could attach it to a different tap, but then would need to change the nfb values ....
And since the several taps are coupled to give 99.8% the same signal (at different voltage), only rabid hi-fi fans could care. Yes, keep the same NFB tap as designed even it you put speaker on another tap.
Offline jrc111
« Reply #6 on: June 24, 2021, 01:44:39 pm »
Awesome stuff.  Thx!
