September 14, 2026, 08:46:37 am
Hoffman Amps Forum image Author Topic: Opinion On Using This as An Output Transformer  (Read 6200 times)
Offline Pollys13a
  • Rock n Roll Tunes For Grown Up Goons.
« on: July 16, 2021, 03:08:36 am »
Just starting on tube amp design and building. This seems a very reasonable price.
Cheers.
Offline Latole
Re: Opinion On Using This as An Output Transformer
« Reply #1 on: July 16, 2021, 03:32:46 am »
1- It is a Power transformer not Output transformer. See screen shot here.
2- It is for 230 volts wall voltage, do you live in Europe ? It do not work in North America
3- Wich amp do you want to built ?
What is you skill in building amp ? Best is to start to built a know amp...from a kit ?
To design a amp who will play well is not a easy job.
« Last Edit: July 16, 2021, 03:41:24 am by Latole »
« Reply #2 on: July 16, 2021, 04:53:24 am »
"...Dedicated heat dissipating black paint, beautiful appearance..."
This screams cheap Chinese to me.
Offline Latole
« Reply #3 on: July 16, 2021, 05:27:38 am »
Hard to tell with AliXpress.
I order some parts, not electronics, the one I receive are good quality
Offline Pollys13a
« Reply #4 on: July 16, 2021, 05:55:14 am »
" What is you skill in building amp ? " Mostly theory, Radiotron Designers Handbook, Merlin Blencowes books, Morgan Jones,Kuehnels books etc. Have Hamtek scope, signal generator, learning about these and how to use them. Uncle Dougs YouTubes.
Offline Latole
« Reply #5 on: July 16, 2021, 06:02:32 am »
Very good theory books.
So you've never built an amp before!
How do you explain that you confused an output transformer with a power transformer?
« Reply #6 on: July 16, 2021, 06:37:22 am »
Nothing in the product info regarding the spec / rating of the wire insulation used to wind it. Ok, Hammond etc don’t tend to either, but they’ve got a reputation to uphold.
Offline Pollys13a
« Reply #7 on: July 16, 2021, 07:05:00 am »
Mum bought me a shortwave radio tube kit.
I was curious and did a quick Google to see what was out there, the Ali listing caught my eye because of the good price, didn't look at listing that closely, misread it.
Offline Pollys13a
« Reply #8 on: July 16, 2021, 07:07:24 am »
The Ali sellers should be able to supply the information.
Offline Latole
« Reply #9 on: July 16, 2021, 07:14:35 am »
Offline acheld
« Reply #10 on: July 16, 2021, 09:42:21 am »
You're right, they should, but they probably do not have the information.
If you're interested in building an amp, my suggestion is that you start with a simpler design than what is implied.
There is a lot to learn.  Not just the theory, but the skills needed for sourcing your parts, your chassis, the build itself, the inevitable troubleshooting, and -- finally -- the glory of a beautiful sounding amp that you have put together.
A reasonable place to start is with Hoffman amps designs and kits.  These are not complete kits -- you will have to source transformers and chassis -- but we have a lot of experience guiding folks through these builds.  Believe me, you will learn a lot, and it is fun.   Not cheap, though.    Another way to go is something like a Mojotone kit, and there are others.
If you've read even one of the books you've cited, it's time to build!
Offline Pollys13a
« Reply #11 on: July 16, 2021, 10:03:04 am »
OK thanks.
Offline Latole
« Reply #12 on: July 16, 2021, 03:12:05 pm »
Building a amp is not like building a furniture or assembled plastic car.
You need to know how and where put grounds and run wire just to name a few. Not only soldering wires between part..
Offline Soulfetish
« Reply #13 on: July 22, 2021, 08:57:46 pm »
Well.... actually, it could work in N. America. It looks like there are two pairs of identical secondaries, so at 120V, He would only need to wire each identical winding in series with each other to recover the voltage. But it would work fine, provided the load on the secondary didn't overload the rating.
Offline Bieworm
  • I like it loud!
« Reply #14 on: July 23, 2021, 07:12:07 am »
Aliexpress is not the right webshop to buy parts for amps except knobs or other cheap plastic stuff. Our western suppliers buy asian plastic parts too...
But the heart of an amp should be a safe and reliable part , not some Chinese ripoff
