September 07, 2026, 06:54:01 am
Hoffman Amps Forum image Author Topic: LED hookup info  (Read 36695 times)
LED hookup info
« on: July 19, 2021, 10:40:54 am »
The LED's listed in my store are on this page
https://hoffmanamps.com/MyStore/catalog/Lamps.htm
The hookup info for all the colors is listed below
5mm diameter LED's
Run them below 20 milliamps to be safe
A 100 ohm current limiting resistor works well with all colors if you are using the 6.3 volts heater circuit in an amp
Do not hook these up to a voltage without a current limit resistor
The long lead is the Anode +
Go to this page to use my handy current limiter resistor calculator
https://el34world.com/php/LedCurrent/LedCurrent.htm
« Last Edit: July 19, 2021, 10:49:29 am by EL34 »
