September 16, 2026, 08:30:50 pm
Hoffman Amps Forum image Author Topic: Princeton reverb reissue started ticking  (Read 7417 times)
Offline Joe6v6
  • Kill Ugly Radio !
« on: August 02, 2021, 09:02:27 pm »
I have a princeton reverb reissue that started ticking with the tremelo on. The speed increases with the speed knob, the intensity knob does not affect it. If I shut the reverb off it goes away & the reverb knob acts like a volume control for the tick, with the reverb knob at zero it goes away. With the reverb off the tremelo work fine with no noise.  .   Any ideas? Ive tried swapping preamp tubes with no affect.  .   Joe
Tubeaholics dont want recovery they want tone!
Offline jordan86
Re: Princeton reverb reissue started ticking
« Reply #1 on: August 02, 2021, 09:28:05 pm »
How old is the amp?
Offline Joe6v6
  • Kill Ugly Radio !
« Reply #2 on: August 02, 2021, 09:37:13 pm »
 Its 4 years or so old,  never had any issues. Only gets played at home so it hasnt been thrown around or anything.
Offline Latole
« Reply #3 on: August 03, 2021, 03:10:28 am »
« Last Edit: August 03, 2021, 03:13:25 am by Latole »
« Reply #4 on: August 03, 2021, 07:01:11 am »
Unplug the footswitch. Still tick?
Offline Joe6v6
  • Kill Ugly Radio !
« Reply #5 on: August 03, 2021, 07:22:52 am »
Princeton 65 reissue ?
Yes & that schematic looks to be correct
Microphonic tube ?
No , Ive already swapped several different tubes in & out.
Offline Joe6v6
  • Kill Ugly Radio !
« Reply #6 on: August 03, 2021, 07:26:19 am »
Unpluging the foot switch stops the tick but it also shuts off the tremelo, the reverb stays on.
« Reply #7 on: August 03, 2021, 08:38:25 am »
Really? The schematic shows that the tremolo will still be enabled with the footswitch unplugged.
Offline jordan86
« Reply #8 on: August 03, 2021, 10:19:24 am »
Could it be lead dress or connections around the reverb and trem jacks? The circuits aren’t really connected on a schematic level. But in the layout they interact at the footswitch jacks. I’d check grounds, jacks, and lead dress around the footswitch connections.
Offline Joe6v6
  • Kill Ugly Radio !
« Reply #9 on: August 03, 2021, 10:28:55 am »
Correction - I didnt pay close enough attention - When the footswitch is unplugged the tremelo and the reverb operate
        correctly with no ticking.   .
« Reply #10 on: August 03, 2021, 11:02:56 am »
When the footswitch is unplugged the tremelo and the reverb operate correctly with no ticking.   .
The typical Fender two button FS has three conductors in the cable. The reverb uses a shielded wire and the tremolo just has a single unshielded wire. The tremolo switch uses the reverb shield for a ground. Inspect the cable at the plug end and at the FS end for a bad shield connection. Even better, replace the cable with a cable that contains two separate shielded wires.
Offline Joe6v6
  • Kill Ugly Radio !
« Reply #11 on: August 03, 2021, 12:08:52 pm »
Will Do - Thanks & I will report my findings.   .
