August 29, 2026, 07:29:57 pm
Hoffman Amps Forum image Author Topic: Twin Reverb Vibrato  (Read 6296 times)
Offline aajeffcote
Twin Reverb Vibrato
« on: August 05, 2021, 03:38:51 pm »
Just finished a Twin Reverb AB763 build. I tried the bias vary vib and the bias current swing scared me away. So I put the roach in. It works good, sounds good but the intensity control does nothing from 1 to 7, so all the adjustment happens very quickly from 7 to 10. Its a new CTS 50K RA pot. Used the ground buss across the back of pots grounded at the jacks. What can I do aboit this?
Offline Raybob
    • Tube-Tone Amplifiers
Re: Twin Reverb Vibrato
« Reply #1 on: August 05, 2021, 05:44:48 pm »
Double check all component values and all wiring dealing with v5.  Something isn't right.
« Reply #2 on: August 05, 2021, 11:03:17 pm »
Bias current swing is how it works. Why is that scary?
« Reply #3 on: August 06, 2021, 05:24:20 am »
You may be interested in this thread...
     https://el34world.com/Forum/index.php?topic=24334.msg261229#msg261229
And here's a link to my web page with just the important info...
     http://sluckeyamps.com/trem/trem.htm
Offline aajeffcote
« Reply #4 on: August 09, 2021, 09:28:23 pm »
Swing was maybe 35 - 107.  Dont think the tubes would take that very long. I tend to use vibrato and reverb a lot.
I went over every component, checked values, voltages and schematic. Finally pulled that 50K RA pot to check it. I had put a 250KA in for the bias vary and did not swap it⁸ out. Fixed that today now the vib is apparent at about 4. Also slowed it down swapping the .01 caps for .02s.
Could be stronger but it sounds good.
Offline aajeffcote
« Reply #5 on: August 09, 2021, 09:38:28 pm »
OK, thank you. I have to try the Tremonator now.
I did try a boost with just a 1meg resistor and an .o1 cap. Cap to the volume input and 1meg to pin 1 V1. Too much boost but it really gets a good lead tone.
« Reply #6 on: August 09, 2021, 11:19:53 pm »
Average of 37 and 107 is 72. Seems like a happy value? Tubes don't blow-up in an instant, or even a trem-a-lo cycle.
Offline aajeffcote
« Reply #7 on: August 10, 2021, 09:15:33 am »
So that is an acceptable swing? OK, I do prefer the bias vary trem over what have now. But first, the Tremonator. Then the best trem wins.
« Reply #8 on: August 10, 2021, 10:54:38 am »
You'll need to be more specific about exactly what those numbers are referring to.
No one here was looking over your shoulder when you made those measurements.
Offline aajeffcote
« Reply #9 on: August 10, 2021, 10:33:52 pm »
Yes. Bias current. The problem was my lack of a thorough check of every component.
Problem solved, thank you.
