September 13, 2026, 08:26:17 am
Hoffman Amps Forum image Author Topic: Can i use this PT for a 50 watt marshall style 2204 build?  (Read 9870 times)
Offline joesatch
  • save me from myself.
« on: September 09, 2021, 07:21:23 pm »
The 2204 layout only uses the secondary Reds and Green for heaters. I would use a FWB.
Re: Can i use this PT for a 50 watt marshall style 2204 build?
« Reply #1 on: September 09, 2021, 07:35:01 pm »
Yes, but it's more suited for a 2203. You'll want to use brown wires for your bias. Slight modification to the layout.
Offline joesatch
« Reply #2 on: September 09, 2021, 07:56:34 pm »
Which tap would you use for the bias? The 2203 uses like 100v. these browns supply 52V. I'm guessing because the 2204 uses 2 power tubes vs 4 the bias tap can supply half as much?
« Last Edit: September 09, 2021, 08:31:05 pm by joesatch »
« Reply #3 on: September 09, 2021, 08:34:37 pm »
Deja vu! Is this the same PT you were gonna use on a twin reverb recently?
Offline joesatch
« Reply #4 on: September 09, 2021, 08:38:07 pm »
indeed. i've ordered a new PT for my AB763 build for tube rectifier.
« Reply #5 on: September 09, 2021, 08:42:29 pm »
Use the browns. Tape off the brn/yel.
« Reply #6 on: September 09, 2021, 08:56:26 pm »
No.
Negative bias uses the same total -dcv using 2 or 4 or 6 or 8 tubes. And -bias draws no current, except the charging current for the bias cap(s), so no increase in -bias current draw for more than 2 tubes.
« Last Edit: September 10, 2021, 09:03:46 am by Willabe »
Offline joesatch
« Reply #7 on: September 10, 2021, 08:17:45 am »
Starting to understand this. For the bias circuit it will be fed with the 50V ac wire from the PT. There are 3 brown wires do i just connect one brown and tape of the other two or does one of the others go to ground?
« Reply #8 on: September 10, 2021, 08:36:59 am »
We already discussed this. Read your twin reverb thread again.
Offline joesatch
« Reply #9 on: September 10, 2021, 08:51:26 am »
thanks sluck as per your own words "you will tape off the BRN/YEL wire and connect one BRN to the bias board and the other BRN to ground. "  :worthy1:
« Reply #10 on: September 10, 2021, 08:59:24 am »
See joesa, you got this stuff.  :wink:
Offline joesatch
« Reply #11 on: September 10, 2021, 09:40:16 am »
really cant see where on a 2204 this 50v would go. Im gonna have to build a 2203 with 2 power tubes.
« Reply #12 on: September 10, 2021, 10:03:38 am »
Show us the layout for your 2204.
Offline joesatch
« Reply #13 on: September 10, 2021, 10:43:29 am »
The mojo 800 layout for example. It has the High Voltage CT to ground (red/yellow). Nothing coming outta the PT to the bias circuit.
Offline SILVERGUN
« Reply #14 on: September 10, 2021, 11:35:44 am »
That one taps into one of the HV legs for the bias supply.
Yours has a separate winding that can be and should be used in your case.
Offline joesatch
« Reply #15 on: September 10, 2021, 11:49:48 am »
So i would clip and isolate that 220k resistor and connect the 50V to it?
Offline SILVERGUN
« Reply #16 on: September 10, 2021, 12:02:48 pm »
From a connection standpoint for the bias supply, yes, that's where it would go.
BUT, you would have to change the value of the 220k resistor....
And, obviously, you are aware that the Mojo layout is not showing a FWB for the HT winding, so you'll have to refer back to what sluckey taught you on your other thread
Offline joesatch
« Reply #17 on: September 10, 2021, 12:22:52 pm »
  Correct i will use a FWB and the 220k resistor here i will swap with a 470 ohm. (i think). Same filter cap setup as mojo
« Last Edit: September 10, 2021, 12:42:50 pm by joesatch »
« Reply #18 on: September 10, 2021, 12:29:04 pm »
It seems a beefy PT for a 50 watter, its HT voltage seems likely to be very stiff and up near 500V.
With decent valves, it may end up putting out over 60W clean, 100W overdriven.
Offline joesatch
« Reply #19 on: September 10, 2021, 01:00:09 pm »
