September 14, 2026, 04:00:34 pm
Hoffman Amps Forum image Author Topic: Buss wire  (Read 5948 times)
Offline joesatch
  • save me from myself.
Buss wire
« on: September 17, 2021, 05:10:50 pm »
I have bought this 20ga buss wire. This wire is THIN and i am apprehensive to use it for amp builds. I built a kit amp a few years back and the included buss wire was 3 times this thickness.  Anyone use this?
https://www.tubesandmore.com/products/wire-bus-100-foot-spool-tinned-copper
Offline joesatch
Re: Buss wire
« Reply #1 on: September 17, 2021, 05:24:55 pm »
looks like this is pedal buss wire. doggit
Re: Buss wire
« Reply #2 on: September 17, 2021, 05:26:45 pm »
I use 24 AWG for board jumpers and to lace turrets together. And I use 17 gauge for pot buss.
Offline labb
Re: Buss wire
« Reply #3 on: September 17, 2021, 06:27:43 pm »
Well, 20 ga. is 20 ga. If you think it is too light, take two or three strands, put the ends together in a drill and twist them together...Make it as thick as you like.
Re: Buss wire
« Reply #4 on: September 17, 2021, 08:58:45 pm »
check out the guage of wire on components like resistors and capacitors   ---   20ga is fine for buss wire. double it up if you're worried .
Here  look at this chart and tell me   are you going to exceed the max current of a 20 guage wire in a guitar amp?
 https://www.engineeringtoolbox.com/wire-gauges-d_419.html
https://www.powerstream.com/Wire_Size.htm
« Last Edit: September 17, 2021, 09:09:45 pm by mresistor »
Re: Buss wire
« Reply #5 on: September 18, 2021, 07:21:23 am »
20 gauge wire is perfect for bus wire
24 is great also
https://hoffmanamps.com/MyStore/catalog/parts18.htm
Offline Fresh_Start
  • noob de Lux
Re: Buss wire
« Reply #6 on: September 18, 2021, 11:51:16 pm »
I have used common house wire (12 ga. ?) for a ground buss. Not for electrical reasons but mechanical. My boards have 2 eyelets at either end of the preamp.  I put the buss wire through the eyelet, making a Z above and below board for mechanical anchor and then solder it in place. This way I have a nice, rigid ground buss running along the edge of the board. Connections come from board and from pots. One chassis ground by input jack(s).
It is not convenient to have to tin the buss using flux for each connection, but it’s worked well for over a decade in 3 builds. Is it overkill?  Probably.
Chip
« Last Edit: September 18, 2021, 11:53:43 pm by Fresh_Start »
Quote from: jjasilli
Quote from: PRR
