September 14, 2026, 09:47:22 am
Hoffman Amps Forum image Author Topic: EL84 amps  (Read 4305 times)
Offline Mehfuzhoss
EL84 amps
« on: September 20, 2021, 04:47:16 pm »
Hello,
So far I built lite, brown note d'lite. I notice that the d'lite has a little bit soft feel, spongy and not very sparkly. whereas, the lite el84 has more sparkle and gritty sound to it. I like el84s because they are cheap and 9 pins tube.
my question is, if i use 100uf filtering caps on a el84 amp will it make it softer. also, please describe soft/ hard filtering.
does choke use make an amp softer?
i really like the d'lite clean tone but the OD is little harsh.
based on your opinion i will decide what to build next :D
thanks
Offline labb
Re: EL84 amps
« Reply #1 on: September 20, 2021, 08:01:40 pm »
You might want to take a look at the Trainwreck Rocket and Liverpool filtering. Easy enough to find audio clips of bothering
