September 08, 2026, 12:13:28 pm
Hoffman Amps Forum image Author Topic: Red Box cabinet emulator VS. speaker  (Read 11456 times)
« on: September 21, 2021, 08:52:20 pm »
Not an apples to apples demo, I admit.    I used two different amplifiers and two different guitars.   One amp has 6BM8 tubes and a hollow body f-hole Tele with single coil type pickups was used.   The other amp had 6V6's and a 335 copy was used with humbuckers.
Having said that ...............................       Here is the sound clip :   https://soundclick.com/r/s8itsr
There are two versions of a jazz song.   Version A   Version B
There are two versions of "Over the Rainbow"   Version A   Version B
There are two versions of "Georgia"    Version A    Version B
Can you tell which version of which song is used a Hughes & Kettner Red Box cabinet emulator  VS.  an amp with a speaker cabinet?   :icon_biggrin:
The same amount of very slight delay, very slight compression and EQ was used on both recordings.  So that aspect is apples to apples. NO effects pedals were used. Just straight guitar into amp on each.
With respect,  Tubenit
« Last Edit: September 22, 2021, 06:38:16 am by tubenit »
Offline Auke Jolman
Re: Red Box cabinet emulator VS. speaker
« Reply #1 on: September 22, 2021, 12:53:00 am »
Hi Jeff,
Can't tell which is which.......
Very impressive.
With Regards,
Auke
« Reply #2 on: September 22, 2021, 05:55:47 am »
I will post which is which at the end of today 9-22-2021.  THANKS for listening!    :icon_biggrin:
Jeff
Offline 1blueheron
« Reply #3 on: September 22, 2021, 10:22:05 am »
I'll play....
I hear distinct differences.  Which is "better"  is hard to say depending on what the goal was. Here are my guesses
Song 1:  A speaker  B  emulator
Song 2:  A emulator, B speaker
Song 3:  A speaker,  B emulator
I am calling the speaker the one that sounds slightly more distant, with slightly less volume and more "artifacts" that would lead me to believe it is a live acoustic recording.
The one I am calling emulator sounds closer, slightly louder and cleaner with less acoustic artifacts leading me to believe it is a direct electronic recording.
Having never heard the amp, cab, or red box emulator, I could have these backwards.
Was the cab close miked or miked at a distance?
In either case, it is quite good. Kudos.
« Reply #4 on: September 22, 2021, 11:40:31 am »
THANKS for participating!   I truly appreciate it very much!
Sent you a PM with the answers.
Yes, the cab was closed mic'd.
Best regards,  Jeff
« Reply #5 on: September 22, 2021, 08:08:28 pm »
Red Box cabinet emulator was
Jazz A
Rainbow B
Georgia A
The speaker was 12” in a Fender SuperSonic22 open back cabinet with a Shure 57 mic’d close on speaker.
Thank you all for the responses, I truly appreciate it.
Best regards. Jeff
