August 29, 2026, 09:09:10 pm
Hoffman Amps Forum image Author Topic: My Princeton Reverb Build. Too much reverb, Too fast tremolo  (Read 7059 times)
Offline dragonbat13
« on: September 24, 2021, 10:36:35 pm »
How do I go about slowing down the bias vary vibrato?
also what are the different methods for reducing the heavy reverb? Mine is just too surfy!
Offline Latole
Re: My Princeton Reverb Build. Too much reverb, Too fast tremolo
« Reply #1 on: September 25, 2021, 03:41:53 am »
Show us schematic as built.
Is it a kit ? Or from scratch ?
Did you use the right Power Transformer ?
Give us more information
« Reply #2 on: September 25, 2021, 07:07:32 am »
See attached for tremolo speed. The easiest thing to do for the reverb is change the reverb pot to a 100K audio taper pot. You'll still have the same amount of reverb but you will have much better control and can easily set a small amount of reverb. For even more control, replace the 1M resistor on the driver tube grid with a 1M-A dwell pot.
Offline jordan86
« Reply #3 on: September 25, 2021, 08:24:45 am »
Yes, what Sluckey said on the 100ka pot for the Princeton. I’ve tried swapping the 1m grid leak into the reverb circuit and it was less helpful than I expected it to be. You could try it though. It changes the vibe of the reverb more than I preferred. I think a audio taper pot is a better approach.
As for the trem, simple fixes. See Rob Robinette’s two component swaps. Another .02 cap and 470k resistor. I used a 433k (470k measured low) and I wouldn’t go any lower. This makes it real slow and swampy. Very brownface Princeton. Almost swallows the attack of the note. The cap change slows it down. The resistor makes it deeper. If you just want it slower the .02 cap is all you need. If you don’t have a .02 and can parallel a second .01 in with the “middle” cap of those three on the layout.
https://robrobinette.com/images/Guitar/AA1164/AA1164_Tremolo_Depth_Mod.png
« Last Edit: September 25, 2021, 08:27:11 am by jordan86 »
Offline dragonbat13
« Reply #4 on: September 25, 2021, 02:32:38 pm »
Just to try, I put a RCA blackplate into the reverb driver socket and it tamed the reverb alot.  Not sure how long that tube is gonna last though.
Ill try the  tremolo speed mods .  Thanks
Offline Latole
« Reply #5 on: September 25, 2021, 02:38:05 pm »
Did you use those tubes models ?
Offline dragonbat13
« Reply #6 on: September 25, 2021, 05:56:19 pm »
For the most part yes.  I used dougs schematics and layout.
https://el34world.com/Hoffman/files/Hoffman_PrincetonReverb.pdf
Offline dragonbat13
« Reply #7 on: September 25, 2021, 05:58:32 pm »
It was parts sourced from different places.  Doug supplied most of the components.  PT is a princeton reverb PT from Classic Tone, Output is also from classic tone.  Everything was correct application for the amp.
used dougs schematic and layout.
Offline jordan86
« Reply #8 on: September 25, 2021, 06:17:34 pm »
Here are the two components for that layout.
