September 14, 2026, 08:45:27 am
Hoffman Amps Forum image Author Topic: Shocking!  (Read 4698 times)
Offline tubesornothing
Shocking!
« on: October 02, 2021, 09:26:53 pm »
A friend has a tube Amp that has an old 2 prong plug and is causing shocks when touch the chassis, and the person touches ground.  I will replace with a 3 prong plugs, but I think the problem is more serious.
When I measure from chassis to ground, 1 get zero volts when powered off.  Regardless of the polarity of the ac plug.
When I do the same measurement with it powered on, I get approx 70 volts.  One time it showed 350v.
What is my next step in diagnosis of the leaky component?
Re: Shocking!
« Reply #1 on: October 02, 2021, 09:31:30 pm »
Which amp?
Re: Shocking!
« Reply #2 on: October 02, 2021, 11:49:53 pm »
It may not be wrong for an UN-grounded amp to show half the wall voltage. That's what it would drift to if everything were equal.
You could be curious and try a 50k resistor to wall ground. Does the floating voltage change?
However a SOLID ground is best, because if a major leak happens it will blow the cellar fuse.
Re: Shocking!
« Reply #3 on: October 03, 2021, 12:02:31 am »
Thanks guys,  I will try the experiment.  This is a jukebox Amp.  I will see if I can dig up a schematic.
Re: Shocking!
« Reply #4 on: October 03, 2021, 12:13:39 am »
