September 15, 2026, 04:06:20 am
Hoffman Amps Forum image Author Topic: My AB763 doesn't like NFB  (Read 46733 times)
Re: My AB763 doesn't like NFB
« Reply #100 on: November 03, 2021, 04:27:45 pm »
SG:
What post and what pic are you referring to?? The bias supply has been completely redone and the tremolo and reverb have been bypassed.
There are no blue wires on the bias suppl, the the bias adjustment pot is connected to the pair of 220k resistors.
BL
Sorry, BL.
I got hit with a couple phone calls and wound up editing my post while you were posting. I was referring back to Reply #6 for pics.
And I'm just here to throw darts that you haven't yet.
I can't believe this is still going on. Good luck.
« Reply #101 on: November 03, 2021, 05:05:36 pm »
the noise is most noticeable at half volume playing an F note at the 13th fret.
that sounds like a rabbit hole of it's own  :laugh:
might figure out what frequency F on the 13th fret equals and use that as your input signal for scoping.
your description sounds like a harmonic distortion which will be hard to "see" on a scope.
when volume get to near max does the amp become normal?
« Reply #102 on: November 03, 2021, 05:53:49 pm »
Scopin;
Put ch 1(or A) on the tip input jack, ground to chassis
Put CH 2 (B) on the Speaker +, ground to chassis
Set your input signal amplitude to 100mV rms (everyone has their favorite #)
Leave it alone
Set tone pots to 5.  Bring volume pot from 0 to 10 real slow.
See any oddities? Get a screenshot, image and post
If nothing jumps out
Vol 5  tone pots 0 to 10
Oddities?
The 2 pics are from my last build.  The 1st is what you should see, both in and out the same.
The 2nd pic is an intermittent harmonic distortion when volume gets ~~ 7-8
It’s still there a year later, I just don’t “warranty” volume >7 :icon_biggrin:
Offline Blind Lemon
  • Do you smell something.....OH Crap! It's smokin'
« Reply #103 on: November 03, 2021, 06:16:51 pm »
Hey guys, got the scopes. Will mess with them in the morning after I get the slaved in choke and power transformer out and the original parts back in.I'm going to configure the circuit without the trem and reverb as slucky suggested and try to find the distortion from there.
Since this is kind of a new start with this issue and this tread is getting so long, and not everyone has read all the post I was thinking of starting anew thread restating the issue, in the first post, as I have become educated with what it is and when this distortion happens.
What do you think, new thread or keep this one going?
Either way nothing is going to happen till tomorrow morning. :icon_biggrin:
BL
Offline dude
« Reply #104 on: November 03, 2021, 09:22:02 pm »
Why wound you even consider a new post…? Work out the issue right here. You have the greatest minds helping you.  I know this is very frustrating for you but a component or wire mishap, or whatever is is the culprit, you just need to find it. You’ve rebuilt the amp, obviously you repeated the problem..? Maybe not, but…, keep the post here.
You just need to step aside for a day or so, go over every wire again, check components, there’s a mistake somewhere..?
Offline Blind Lemon
« Reply #105 on: November 04, 2021, 10:14:29 am »
Ok I'll keep it here.
Working putting the original choke and PT in the circuit.
Also the scopes work, but the 455 I can only get channel 2 to read anything. The Ballentine works on both channels.
Back to the amp.
BL
« Reply #106 on: November 04, 2021, 10:55:24 am »
Have you tried another guitar with this amp?
What other amps do you have?
Offline Blind Lemon
« Reply #107 on: November 04, 2021, 11:54:20 am »
Yea, I've tried 3 different guitars with 3 different cables, 3 different instrument cables and the same number of speaker cabs.
Amps: Starting left to right.
TW Rocket no cab
EL86 Plexi no cab
Mongral no cab
5881 Princeton /correct transformers to support the 5881s - on floor
Stack:
Revibe
6V6 Plexi
TW Express like amp with 6V6s
EL34 Plexi w/1 input
50w HP Tweed Twin w/BF Super OPT
Fender Reverb unit
And one that I didn't build in black tolex behind the tweed is a hot rodded Princeton.
Not showing off, but these are a few of the amps I've built. Mostly scratch built with new parts and transformers.
I enjoy building and and playing.
BL
« Last Edit: November 04, 2021, 11:56:42 am by Blind Lemon »
« Reply #108 on: November 04, 2021, 12:34:30 pm »
Nice stable! My question was a leading one. I'm hoping that you can rig up to be able to patch your AB763 preamp into another power amp, maybe the 6V6Plexi (or another amp with a LTP PI). And also patch the 6V6Plexi preamp into the AB763 power amp. Still trying to determine if your issue is in the preamp or power amp. Look at this schematic for an idea how to easily do the patching, or just sit the amps side by side and use gator clip leads.
     http://sluckeyamps.com/november/november.pdf
On another note... I know we've been over this before but I gotta ask again since you have all new components on the board. There are five 1M resistors on the board, but my eyes only see two. The other three look to be 10Ω to me. I've attached your board with the resistors circled. Resistors 1, 4, and 5 look like brown/black/black (10Ω) on my monitor and phone. Resistors 2 and 3 look like brown/black/green (1M) to me. I'm probably just seeing them wrong but will you please verify they are all 1M resistors? See attached pic.
Offline Blind Lemon
« Reply #109 on: November 04, 2021, 01:22:14 pm »
sluckey:
Yes I could slave in another amp if need be. Was hoping the scopes would be of use before all that.  :dontknow:
Yea, those one meg resistors have a sort of forest green color to them.
Here is a pic of the 1meg color and probably what you are use to seeing.
Going to eat a quick bowl of venison stew and be right back. Hell was hoping to get out to do some bow hunting today. Not happening.
BL
Offline Blind Lemon
« Reply #110 on: November 04, 2021, 02:43:26 pm »
So here is where I am right now.
The amp is back with the original components, but the tremolo and reverb are jumped and removed from the active circuit with those tubes pulled. As suggested slucky post #83.
What I am hearing now that I have some history and have done some critical listening. At lower volumes (~8:00) there is a fuzz/grrr on top of the note then as the note kind of dies and a feedback bloom starts it sound like a box of rocks shake. I had a 5751 in it and put a 12ax7 in and it does it more.
So gain seems to have a hand in it.
BL
Offline Blind Lemon
« Reply #111 on: November 04, 2021, 02:56:21 pm »
In these photos of the scope display the bottom trace is the input and the top trace is the probe @ the output of the 220k riz going to the input grid of the power tube.I am no expert at this, but is that fuzz on the top trace distortion? BTW it happens at the output of both 220K riz, 180' out from each other. I wonder why.......... :laugh:
I'm generating the freq. with a plucked open low E.
Help me understand or confirm what I am seeing.
BL
« Reply #112 on: November 04, 2021, 03:37:20 pm »
your input signal (bottom trace?) looks like it's missing a ground reference
and ya, those RF bursts are not good.  measure again at the "left side" of the coupling caps that feed the PI
MAKE SURE the scope is set for AC coupling.  there will be biggish DCV there
Offline Blind Lemon
« Reply #113 on: November 05, 2021, 09:53:56 am »
Got a few screen shots.
I'm using a freq. generator of of my iPad.
82hz (low E) @~ -4db
amp has volume control at about 8:00, using a speaker for load, I also have a bigass (technical term) 8 ohm load I could use.
Bottom trace is always the input.
First photo @ output jack.
BL
« Last Edit: November 05, 2021, 10:09:13 am by Blind Lemon »
Offline Blind Lemon
« Reply #114 on: November 05, 2021, 10:09:56 am »
After PI.
Offline Blind Lemon
« Reply #115 on: November 05, 2021, 10:10:36 am »
Before PI
« Reply #116 on: November 05, 2021, 10:13:13 am »
PI input good. PI output bad. Looks like the problem is in the PI. Do both PI outputs look like crap?
Offline Blind Lemon
« Reply #117 on: November 05, 2021, 10:21:56 am »
yes
« Reply #118 on: November 05, 2021, 10:25:05 am »
Disconnect NFB wire and post new pics of PI outputs. Instead of calling them PI 1 and PI 2, call them pin 1 and pin 6.
Offline Blind Lemon
« Reply #119 on: November 05, 2021, 10:35:50 am »
Coming your way
Offline Blind Lemon
« Reply #120 on: November 05, 2021, 10:40:15 am »
Here you go
« Reply #121 on: November 05, 2021, 10:48:35 am »
Much better without NFB. I seem to remember that you have modified the NFB to some fancy robrob circuit? If so, can you bypass that and just use the standard AB763 circuit, ie, 820Ω and 100Ω (or 47Ω) voltage divider network? Also, how is your speaker jack grounded. I like to run a dedicated ground wire from the jack over to the power ground point, even if I'm using a Switchcraft 12A jack that automatically grounds to the chassis.
Offline Blind Lemon
« Reply #122 on: November 05, 2021, 10:54:07 am »
Not a great pic.
Thats the NFB to circuit wire flying up.
« Reply #123 on: November 05, 2021, 11:04:53 am »
Disconnect that NFB switch from the speaker jack and connect a 820Ω resistor from the speaker jack directly to the 100Ω onboard resistor, just like Hoffman did. Also run a dedicated ground wire between the speaker jack and your power ground point.
Offline Blind Lemon
« Reply #124 on: November 05, 2021, 11:10:45 am »
Did it.
Jumper wire to PT ground and 820 to the 100 on the board.
Same, same.
When I lift the 820 it cleans up.
BL
Offline Blind Lemon
« Reply #125 on: November 05, 2021, 11:12:34 am »
I'm replacing jacks.
« Reply #126 on: November 05, 2021, 11:29:38 am »
With the scope on the output does the signal amplitude change when you connect the NFB versus no NFB?
I'm beginning to suspect power grounding scheme. Can you take some more closeups that show every filter cap and it's ground connection. Probably take 3 or 4 pics to show it all.
Offline Blind Lemon
« Reply #127 on: November 05, 2021, 11:36:03 am »
Jacks didn't help
Give me a couple and I'll get pics
BL
« Reply #128 on: November 05, 2021, 11:36:27 am »
Take a look at the ground path through the bias pot body, if that is still the way you have it set up.
Not only does that ground the bias circuit, but it handles the output tube grid leaks as well.
Offline Blind Lemon
« Reply #129 on: November 05, 2021, 12:16:26 pm »
Here they come.
Offline Blind Lemon
« Reply #130 on: November 05, 2021, 12:17:21 pm »
Nodes B,C
Offline Blind Lemon
« Reply #131 on: November 05, 2021, 12:18:13 pm »
Preamp end
Offline Blind Lemon
« Reply #132 on: November 05, 2021, 12:20:33 pm »
SG: Checked it a couple days ago and made sure it had one of the big lock/grounding washers under it.
BL
« Reply #133 on: November 05, 2021, 12:52:55 pm »
If the jacks don't work;
try putting a 500pF to .001uF across both PI plate R's (one cap on each R)
Offline Blind Lemon
« Reply #134 on: November 05, 2021, 01:00:50 pm »
Sorry, I missed this.
Yes volume decreases quite a bit.
BL
« Reply #135 on: November 05, 2021, 01:48:25 pm »
Where is the PT HT center tap???
I don't like the B and C ground point. It requires current for those caps to travel through the chassis to get back to the HT center tap ground point.
Ideally you want the PT center tap, first filter cap, B cap, C cap, bias board ground, bias pot ground, and that power ground buss on the board to all be connected to the same chassis ground lug. Try moving the B and C grounds IAW attached pic first.
« Reply #136 on: November 05, 2021, 03:07:21 pm »
The 1st B+ cap's ground is going through the chassis over to the PT B+ CT ground.
The B+ CT should go directly to that 1st caps ground lead and then run a wire over to your power amp chassis ground. Don't move the cap, move the PT CT and run a wire back to the chassis power ground.
Do what Sluckey wrote 1st and see if that gets rid of your problem. If it doesn't or only gets part of it then try what I wrote.
« Last Edit: November 05, 2021, 03:30:54 pm by Willabe »
Offline Blind Lemon
« Reply #137 on: November 05, 2021, 04:06:19 pm »
No luck on both accounts.
BL
Offline dude
« Reply #138 on: November 05, 2021, 04:06:47 pm »
I always grounded the CT, nodes, A,B,C all to the same point with the speaker ground, bias ground. The preamp filter ground opposite end of CT, run a buss (picking up other grounds) hanging free on one end all to bolt on chassis near the input, l even run a short lead from input ground to that bolt. Never had any noise or any issues.
« Last Edit: November 05, 2021, 04:08:54 pm by dude »
Offline Blind Lemon
« Reply #139 on: November 05, 2021, 04:26:53 pm »
This amp was never noisy at idle or low volume. But I consolidated my power grounds to one place.
BL
« Reply #140 on: November 05, 2021, 04:27:30 pm »
Did you test it after moving those grounds with the speaker jack still jumpered over to the chassis power ground?
Are you using bias vary trem? If so that needs to get grounded with the power amp grounds.
How did you ground the power tubes K's?
Offline Blind Lemon
« Reply #141 on: November 05, 2021, 04:30:58 pm »
Changes sluckey suggested.
Offline Blind Lemon
« Reply #142 on: November 05, 2021, 04:32:43 pm »
No luck until I added this.
BL
Offline Blind Lemon
« Reply #143 on: November 05, 2021, 04:37:08 pm »
Sorry..........  :l2:
« Reply #144 on: November 05, 2021, 04:39:36 pm »
Leave the black wire you ran from the 1st B+ cap's ground, but move the B+ CT to that 1st caps ground lead. Your in this far, It may or may not fix it, but, it makes a difference.
« Reply #145 on: November 05, 2021, 04:40:35 pm »
Guess your done for the night.   :laugh:
Offline Blind Lemon
« Reply #146 on: November 05, 2021, 04:46:15 pm »
This took care of it.
« Reply #147 on: November 05, 2021, 04:48:37 pm »
 :blob8:   YES!!!!!!
Across the LTPI's plates?
Offline Blind Lemon
« Reply #148 on: November 05, 2021, 04:49:39 pm »
So my first question was >>>>>> Why doesn't my amp like NFB.
I'm going to stop for this evening and take a look at it again in the morning, but the amp sound a whole hell of a lot better now.
BL
Offline Blind Lemon
« Reply #149 on: November 05, 2021, 04:51:34 pm »
Yes, across the PI plates. :d2:
BL
