September 16, 2026, 05:21:02 am
Hoffman Amps Forum image Author Topic: Marshall VS100 Power Transformer Repurpose  (Read 4345 times)
« on: October 16, 2021, 08:56:47 pm »
Hi guys, Got a a dead VS100 combo.
I think the PT could be used for the HT supply.
Anyone have any idea of current capacity.
Marshall_marshall_vs100_2.pdf (el34world.com)
Marshall_marshall_vs100_3.pdf (el34world.com)
Re: Marshall VS100 Power Transformer Repurpose
« Reply #1 on: October 16, 2021, 09:01:27 pm »
Is that the whole thing? One small tube and some small chips? Or is there more?
« Reply #2 on: October 16, 2021, 09:28:41 pm »
Hi PRR,
I'm only guessing here..
The supply to the 12ax7 is 240ac and is about 340v rectified.
It has a 250mA fuse, so I would think it could be good to supply 3-4 12ax7s
The supply to the main amp is is a 64v CT, put this through a quadurpler could supply approx. 330v but the current is unknown.
It has a .5w fusible resistor, if that is a clue.
Heaters would be supplied via a separate PT
The heater supply would be good for one tube, has a fuse of 250ma
« Reply #3 on: October 17, 2021, 12:04:03 pm »
It will heat one small tube wired at 12V.
The power amp ate 88VDC @ 1.8A DC, so say 350V 450mA. A 12-pack of 6V6??
