September 16, 2026, 04:26:13 am
Hoffman Amps Forum image Author Topic: Adding cathode follower to Thunderbolt/6420  (Read 4599 times)
Offline big-ez
« on: October 17, 2021, 08:50:27 am »
I've built of clone of the Supro Thunderbolt (6420). Schematic here:
https://el34world.com/charts/Schematics/Files/Supro/Supro_6420tr_tbolt.pdf
I want to use the extra triode in V1 to put a cathode follower before the tone control. Is this schematic correct? Do I need a coupling cap where I wrote in the '??' to prevent DC from reaching the tone pot? If so, what value?
Re: Adding cathode follower to Thunderbolt/6420
« Reply #1 on: October 17, 2021, 12:08:33 pm »
The grid circuit of your CF is wrong and will not work. You do need a coupling cap where you indicated. Use same value as other coupling caps in the amp. Here's some good basics on cathode followers...
     http://www.valvewizard.co.uk/accf.html
     http://www.valvewizard.co.uk/dccf.html
BTW, I noticed you are currently posting about this amp using two accounts, big-ez and ampnewbie. Why?
Offline ampnewbie
« Reply #2 on: October 17, 2021, 12:29:45 pm »
Yeah, the 2 accts is annoying. My phone auto logs me in as one and my PC as the other. Will fix.
Thanks for the advice, appreciate it!
« Reply #3 on: October 17, 2021, 01:21:52 pm »
That's an easy fix right here on the board. Just log in using the device that has the user name you DON'T want to use. Then log out. And immediately log back in, but use your preferred username/password ***AND*** check the box to keep you logged in forever. You don't even have to let your device "remember" your log in name/pword.
