September 16, 2026, 01:59:11 am
Hoffman Amps Forum image Author Topic: 5e3 head layout  (Read 6072 times)
Offline timmyjoe
5e3 head layout
« on: October 27, 2021, 09:31:33 pm »
Making an amp for a friend. Think I read that it is good to keep the transformers away from other parts.
I am worried about all the weight being in one side. Anything else I should consider?
Re: 5e3 head layout
« Reply #1 on: October 27, 2021, 09:43:11 pm »
The internet is full of pics that show what a successful 5E3 head should look like. I would not stray too far.
     https://www.flickr.com/photos/137947485@N03/sets/72157669582686771
Offline Latole
Re: 5e3 head layout
« Reply #2 on: October 28, 2021, 03:57:47 am »
Keep away Power Transformer from preamp tubes only .
https://www.littledawgamps.com/tweed-deluxe/
Re: 5e3 head layout
« Reply #3 on: October 28, 2021, 05:52:43 am »
Layout is a key aspect of turning a circuit diagram into a correctly working (or otherwise) real world amp.
Until you get a firm grasp on the concepts, to avoid frustration / disappointment, I think it would be better to use a proven design.
Michael at Modulus is a highly competent engineer, see his take on the matter
https://modulusamplification.com/Tweed-Deluxe-Style-Head-Chassis-P5411536.aspx
https://modulusamplification.com/Modulus-Tweed-Deluxe-Head-kit-12-Watt-Output-P5397343.aspx
Most amps chassis are extremely unbalanced, there are pressing constraints to keep power supplies and output stages away from input stages and preamps.
The imbalance isn’t a big deal generally, perhaps consider offsetting the cab handle if that’s still a concern.
« Last Edit: October 28, 2021, 06:04:37 am by pdf64 »
Offline Latole
Re: 5e3 head layout
« Reply #4 on: October 28, 2021, 06:45:34 am »
100% right !
