September 15, 2026, 07:29:16 am
Hoffman Amps Forum image Author Topic: AB763 Bias too cold resistor swap  (Read 4344 times)
Offline joesatch
  • save me from myself.
« on: November 04, 2021, 12:11:33 pm »
In the pic below there are (2) resistors. A 470ohm and a 27k. The common suggestion is to lower the value of the 27k to around 15k to 22k.  I was getting ready to do that when i came across someone recommending to change the 470ohm. Why do that one and what do i change it to? Max setting on my pot gets me to 32ma on these 6L6's. My bias tap is pretty high 66v so this is why i need to change the resistor
« Last Edit: November 04, 2021, 12:13:57 pm by joesatch »
Re: AB763 Bias too cold resistor swap
« Reply #1 on: November 04, 2021, 12:59:43 pm »
Either lowering the value of the 27K or increasing the value of the 470Ω will increase your tube current. I prefer to change the 470Ω resistor. Hoffman even calls this resistor the "Bias Range" resistor on all his AB763 amps. I would increase to 1K and re-evaluate. Increase/decrease again if necessary.
It would be very useful if you tell us what the range of negative voltage on pin 5 of the 6L6s. A range of -45 to -60 is usually good enough to make most AB763 6L6s happy.
Look at this for reference...
     https://el34world.com/Hoffman/files/Hoffman_AB763_2.pdf
