September 15, 2026, 06:39:06 pm
Hoffman Amps Forum image Author Topic: AB763 high voltages help  (Read 8338 times)
Offline joesatch
  • save me from myself.
« on: November 04, 2021, 05:03:11 pm »
'93 Concert converted to FWB rectifier Super Reverb. I have the variac set at 117volts. Well getting some pretty high voltages.
Have the (2) 6L6 tubes at 34ma.
As follows:
Plate  530V
Negative Bias -57.2v (at pin5)
B+ voltages:
A 534v
B 532v
C 518v
D 473v
« Last Edit: November 04, 2021, 06:38:08 pm by joesatch »
Re: AB763 high voltages help
« Reply #1 on: November 04, 2021, 06:06:07 pm »
A 533vB 530vC 530v
are the tubes installed?  there should be a 10's of volts volts difference
measure the VDC on the corresponding pre tube's Cathode's to verify current is flowing
Offline joesatch
« Reply #2 on: November 04, 2021, 06:12:41 pm »
i updated voltages measured. i got one wrong. all the tubes are installed. no issues with the amp sounds good but these voltages are very high. I'm afraid if i take it off the variac something will blow.
v1 302v plate
v2 309v
v3 reverb driver
v4 315v
v5 515v
v6 348v
« Last Edit: November 04, 2021, 06:44:03 pm by joesatch »
« Reply #3 on: November 04, 2021, 06:38:49 pm »
What does the 6.3V heater circuit measure? ie one probe to pin2, the other to pin7, of an output valve socket.
Offline joesatch
« Reply #4 on: November 04, 2021, 06:45:30 pm »
7.18 vac
Doghouse (B leads are soldered underneath):
« Last Edit: November 04, 2021, 06:54:44 pm by joesatch »
« Reply #5 on: November 04, 2021, 07:12:08 pm »
....I have the variac set at 117volts. ...
Set to 117V. What is is actually putting OUT?
Offline joesatch
« Reply #6 on: November 04, 2021, 07:25:05 pm »
i think you're on to something my man. With the variac set at 117v it's actually putting out 130+ volts!
My wall is putting out 121 volts so i set the variac there and re-biased. i think everything is happy now.  :laugh:
« Last Edit: November 04, 2021, 07:33:13 pm by joesatch »
« Reply #7 on: November 05, 2021, 10:25:42 am »
I don't trust those Watt-O-Kills half as far as I can throw them. *Carefully* use a proper meter.
But it does suggest that the "117V" was wrong.
Offline joesatch
« Reply #8 on: November 05, 2021, 10:52:15 am »
Checked it with my Fluke. It's off by 1 volt. Not terribly inaccurate. But you helped me tremendously :icon_biggrin:
« Reply #9 on: November 05, 2021, 10:56:57 am »
What's off by 1 volt? The 117V reading or the 130v reading???
Offline joesatch
« Reply #10 on: November 05, 2021, 11:36:03 am »
The 130v reading from white box. It's actually 131v . The variac dial is way off, having it set to 117v is putting out 131v
« Reply #11 on: November 05, 2021, 11:56:19 am »
You may want to read this topic...  Add a meter to your variac
Offline joesatch
« Reply #12 on: November 05, 2021, 01:07:15 pm »
i wasn't aware the variac had the ability to increase voltage.   I assumed the variac at full would equal the wall outlet direct. Thanks!
« Reply #13 on: November 05, 2021, 01:14:53 pm »
It's an auto transformer, not a rheostat. Mine will take the output up to 140VAC.
« Reply #14 on: November 05, 2021, 10:02:45 pm »
i wasn't aware the variac had the ability to increase voltage...
There's two ways to wire it. Boosting the line is a perfectly reasonable use; it may be why they were so popular in the 1940s.
