September 15, 2026, 08:53:51 am
Hoffman Amps Forum image Author Topic: Strange conversion  (Read 6586 times)
Offline Stuff4bikes
Strange conversion
« on: November 07, 2021, 03:17:20 pm »
I picked this up last night, it's a Baldwin panoramic tone cabinet....
Cant find a schematic for it but looks like it has 3 seperate reverb units
With 2 12ax7's and a gain per spring.
8-12ax7's
2-EL84's
5U4
In total.....
Anyone familiar with this?
Re: Strange conversion
« Reply #1 on: November 07, 2021, 03:57:19 pm »
It's called a necklace reverb. If I had that unit I would try to fix it as is. The electronics chassis is nothing special but the entire unit probably is.
Offline thetragichero
« Reply #2 on: November 07, 2021, 04:31:42 pm »
i have a schematic for the single "delay line" unit that was inside an organ if it would be helpful in diagnosing the reverb part. you may be able to find a schematic/service manual for the whole unit if your googlefu is good enough
Offline Stuff4bikes
« Reply #3 on: November 07, 2021, 04:46:44 pm »
How can I play guitar through it with out destroying it? I can turn the unit on and tap the cabinet and hear the springs through the speaker, not sure if that means anything.
« Reply #4 on: November 07, 2021, 04:52:45 pm »
You'll need a schematic to figure that out. If you post the model number of the unit maybe we can help find some more info. Maybe take a close-up pic of the data plates on the amp and the side of the cab.
Offline Stuff4bikes
« Reply #5 on: November 07, 2021, 05:08:21 pm »
« Reply #6 on: November 07, 2021, 06:30:28 pm »
these are not your exact model (i got them as a reference for a conversion of the amp and reverb unit a friend picked up to send to me), but they should be helpful (yanked them from photos in a reverb listing because the schematics seem harder to find than hammond organ schematics)
i'll do some more looking though
« Last Edit: November 07, 2021, 06:33:48 pm by thetragichero »
Offline Stuff4bikes
« Reply #7 on: November 07, 2021, 08:49:54 pm »
Looks like mine may have a seperate pre amp module. Thanks for all your help so far....
« Reply #8 on: November 08, 2021, 07:16:26 pm »
'Necklace' is the early Hammond. The Baldwin saggy-thing is quite different. It does not pass baseband audio; audio is modulated on a supersonic carrier, passed through spring, and demodulated back to baseband audio. You need both parts.
Offline Stuff4bikes
« Reply #9 on: November 08, 2021, 09:23:10 pm »
I will probably put it away for a long term project then.
{edit- quote tag fixed -PRR}
« Last Edit: November 09, 2021, 10:27:50 am by PRR »
« Reply #10 on: November 09, 2021, 02:59:36 am »
Thanks, I was almost loosing sleep over the amount to tuners in that thing!
