September 17, 2026, 02:54:08 am
Hoffman Amps Forum image Author Topic: Yet another JCM 800 Mod: Good or bad design?  (Read 6529 times)
Offline tmknight
  • Hello
« on: November 14, 2021, 12:05:45 pm »
OK, this is more of a question of "how" to implement rather than "should I".  I've already arrived at what I'm changing and what values will be applied.  My plan is where I'm looking for some constructive feedback.  My approach is to put it on a perf-board so I could completely switch-off the circuit(s) as desired.
Update:
Implemented and safely working as designed.  You may wish to consider an electrolytic for the C2 (layout) bypass cap.
« Last Edit: November 27, 2021, 03:01:41 pm by tmknight »
Re: Yet another JCM 800 Mod: Good or bad design?
« Reply #1 on: November 14, 2021, 12:17:07 pm »
A schematic would be much easier to understand.
« Reply #2 on: November 14, 2021, 12:47:10 pm »
but rather is it safe?
with a schematic it'll be easy to see if you're switching HighVolts DC and signal or just signal
Offline tmknight
  • Hello
« Reply #3 on: November 14, 2021, 02:22:49 pm »
Thanks, gents.  From the "standard" 2204 schematic, splitting the "straight line" V2b cathode to tone stack and inserting the clipping circuit.  So, my thinking is that it is "pure" signal, albeit with quite a bit of DC.  This is a well-known/proven mod in and of itself, just haven't seen it switched in this same way...most leave in the res/cap and "eat" the signal loss.
Thanks, you've given me the pointer that helped me think through it...
Cheers!
Offline thetragichero
« Reply #4 on: November 14, 2021, 04:07:18 pm »
a picture is worth a thousand words, even when it comes to a relatively common design. it's not so much pedantry but accuracy: we wanna make sure your thing works when you're done!
Offline tmknight
  • Hello
« Reply #5 on: November 25, 2021, 10:36:38 am »
 :thumbs:
« Last Edit: November 26, 2021, 02:44:54 pm by tmknight »
Offline 66Strat
« Reply #7 on: November 27, 2021, 09:55:32 am »
Are there posts missing from this thread? I seem to recall at least one post with the layout for this mod that appears to be missing.
Regards,
JT
« Reply #8 on: November 27, 2021, 10:47:25 am »
The layout was in the original post but he removed it yesterday.
Offline 66Strat
« Reply #9 on: November 27, 2021, 11:01:56 am »
So much for information sharing.
Regards,
JT
Offline tmknight
  • Hello
« Reply #10 on: November 27, 2021, 02:51:07 pm »
Updated
