September 16, 2026, 12:45:37 am
Hoffman Amps Forum image Author Topic: NTC Thermistor question  (Read 7542 times)
Offline Esquirefreak
« on: November 17, 2021, 02:36:55 am »
Hello!
I just got a AB763 Showman and it's my first solid state rectified amp in a long time.
I thought that while I'll go over the caps and maintenance stuff, I also want to add 1 or 2 thermistors to slow down the current inrush during start up.
Where in the circuit will a thermistor perform its best? In series with the AC hot before the PT primary, or in series with one of each secondary HT?
Regards from Sweden,
Max
Offline astronomicum
Re: NTC Thermistor question
« Reply #1 on: November 17, 2021, 08:41:25 am »
The Ametherm web site is helpful and has the calculations you would make to determine the best unit.
https://www.ametherm.com/inrush-current/transformer-inrush-current.html
« Reply #2 on: November 17, 2021, 09:26:00 am »
The 65 TWIN REVERB REISSUE (basically same as AB763 showman) uses a C60-11 THERMISTOR in the primary of the PT. Since you're in Sweden you may look at the Tube Amp Doctor replacement thermistor.
« Reply #3 on: November 17, 2021, 09:56:55 am »
I like them in the live mains feed, eg between fuse and switch.
And in the HT supply, eg between the rectifier and reservoir cap.
Be aware they get hot in use, so allow plenty of free space around them.
« Last Edit: November 17, 2021, 12:56:06 pm by pdf64 »
« Reply #4 on: November 17, 2021, 10:59:21 am »
...I also want to add 1 or 2 thermistors to slow down the current inrush during start up....
Why? Are your house wires burning-up?
« Reply #5 on: November 17, 2021, 12:21:39 pm »
Thanks, everyone. I'll probably put one between the mains switch and the fuse as suggested.
As to why - I thought that it couldn't hurt and my understanding is that it is easier on the caps, diodes, PT and pretty much the whole amp. Am I wrong?
/Max
« Reply #6 on: November 17, 2021, 01:02:01 pm »
As I see it, a significant benefit is being able to use quick blow / F spec HT fusing for solid state rectified supplies, without needing to use a higher value fuse.
Hence my hypothesis is that the exposure to / collateral damage resulting from, fault current from valve shorts etc should be reduced.
Offline trobbins
    • Tim's projects and info
« Reply #7 on: November 17, 2021, 03:27:54 pm »
The risk is that you are going to fit a new hot part in to the AC mains primary circuit of the amp - which is the most hazardous location for diyers to work in, especially if there is no convenient set of insulated terminals to easily and safely fit such a hot part.  Imho that risk has more chance of hurt than any perceived feeling of making life easier on other parts.
