July 25, 2026, 12:35:45 pm
Hoffman Amps Forum image Author Topic: Washburn VGA30 Humming  (Read 8725 times)
Offline dpm309
    • Matthews Amps
« on: November 20, 2021, 02:01:31 pm »
Have a Washburn South Side VGA30 with a loud humming problem. Cleaned jacks and pots and getting a loud humming with nothing plugged in and all controls at 0. It seems to be coming from the PT. Getting sound and normal volume with a guitar plugged in. I have not worked on many solid state amps and am wondering where to begin?
Re: Washburn VGA30 Humming
« Reply #1 on: November 20, 2021, 05:05:27 pm »
begin with a schematic
PS, whether tube or SS does basically the same thing, clean, regulated DC to the amp
knowing what the DC values compared to good, as designed, makes life easy.
Offline dpm309
    • Matthews Amps
« Reply #2 on: November 20, 2021, 11:04:34 pm »
Have not been able to find a schematic for this or any Washburn amp. I'll start poking around and get some voltage readings in the power supply.
« Reply #3 on: November 21, 2021, 12:06:43 am »
The SX30 is online: https://elektrotanya.com/washburn_sx12_guitar_amp_sch.pdf/download.html
This is a very basic chip-amp. Simple power supply. I do not know what a "VGA" is, but if similar +/- some frills, the SX12 plan will give a start.
Note that the main power supply is same-as most tube amps, just a fraction of the volts. If you understand how AC volts relate to DC volts, you can figure if the main cap is working or punked-out.
Offline dpm309
    • Matthews Amps
« Reply #4 on: November 21, 2021, 10:58:29 am »
Thanks for the schematic. This gives me a starting point to determine where the excessive hum is coming from.
