September 16, 2026, 01:28:40 pm
Hoffman Amps Forum image Author Topic: Tone King Imperial PI Question  (Read 5788 times)
Offline johngovan
« on: November 21, 2021, 07:10:22 am »
What kind of phase inverter does tone king Imperial use?
I'm planning to make one soon.
Thank you.
Re: Tone King Imperial PI Question
« Reply #1 on: November 21, 2021, 08:43:51 am »
paraphase inverter
Offline Bieworm
  • I like it loud!
« Reply #2 on: November 21, 2021, 03:19:55 pm »
FWIW that's the first thing I changed on my clone. The LTP PI is so much better in it. The volume is uncontroleable with the paraphase
I found the OD channel useless too without the dedicated attenuator.  It's too loud when you want OD
« Last Edit: November 21, 2021, 03:22:35 pm by Bieworm »
Offline johngovan
« Reply #4 on: November 21, 2021, 09:09:36 pm »
Thank you sluckey, Bieworm and PRR. Really appreciate your responses.
Offline johngovan
« Reply #5 on: November 21, 2021, 11:58:46 pm »
Another question. How to identify types of resistor?
Beige color = carbon resistor?
Blue color = metal film resistor?
White color = cement resistor.
Green color = wire wound resistor?
Gray color = ?
Thank you.
« Reply #6 on: November 22, 2021, 02:27:19 am »
Bad Boys Race Our Young Girls.......?
black brown red orange green.....?
surf up "resistor color codes"
Offline johngovan
« Reply #7 on: November 22, 2021, 02:43:33 am »
Thanks shooter for the response. But I'm not after the code but for the type of resistors. How can you identify if that resistor is a carbon film, a metal film, or a metal oxide?
Offline acheld
« Reply #8 on: November 22, 2021, 09:36:59 am »
Don't take this as gospel, but I don't think you can reliably ID a resistor type from the casing.   You can guess, and be right most of the time.
For example, many modern metal film resistors have a blue epoxy casing; Vishay Dale MF resistors, mostly come in a brown excremental looking casing (these are my personal favorites, esp the MILSPEC variety), but they also have some MF resistors in a chalky orange casing that you would swear would be a metal oxide with a flame proof casing.
So, for modern resistors, I don't think you can generalize.
Offline johngovan
« Reply #9 on: November 22, 2021, 05:24:41 pm »
Thank you for the help acheld. It is very clear. Appreciate it.
